UE4 Elemental tech demo available for download
30 Mar 2010
Under The Stairs!
Take Unreal Engine 4 Elemental Tech Demo for a Spin
Wish you could run one of those awesome Unreal Engine 4 tech demos on your own hardware instead of watching its lossy, pixellated video-grabs on YouTube? Well, now you can. Epic's "Elemental" tech demo for Unreal Engine 4 cropped up on the web, and we wasted no time in re-hosting it for you. The demo doesn't appear to be a public release, but something developers put together for demos to be run by Epic and its partners, only. To begin with, it doesn't come with an installer. You have to extract its files into a folder, and manually edit its settings INI file to specify resolution, window behaviour, and other settings. You then have to install VC++ 2013 runtime if you don't already have it (the redistributables are included in the archive), and then run the demo from the relevant batch file. Unreal included both 32-bit and 64-bit executables. When you're done drooling rainbows at the demo, only an Alt+F4 closes the thing down (there's no in-demo UI). There's no internal benchmark, and you're left to use third-party frame-rate loggers. These little issues aside, the demo sure makes Unreal Engine 4 look promising. We also added a collection of five other tech-demos for your viewing pleasure.
from: http://www.techpowerup.com/200291/take-unreal-engine-4-elemental-tech-demo-for-a-spin.html
Download links:
http://www.techpowerup.com/downloads/2369/Unreal_Engine_4_-_Five_Tech_Demos.html (rar archive)
http://www.techpowerup.com/downloads/2368/Unreal_Engine_4_Elemental_Tech_Demo.html
Set your res in the settings, and set exclusive fullscreen on with "0". That little shooter game is a bit mean lol. Epic knows how badly a lot of people want a real sequel to the Unreal series!
Bring on UNREAL III AND UT4!!!!:cool::D I think we'll be waiting a while though unfortunately:(
In case you guys didn't know you can use console commands during the demo:
`Stat FPS
`RestartLevel
`Exit
Lol Looks great but only getting around 17 - 24 fps at 4K. I doubt it is using both my Titans though.
16-30 ON MY 480s (1920 x 1200) Greg:o 4K...4K it stands out like a beacon to me:o not jealous...not jealous at all:o:p
Trying this now :D
How did you find it Frosty?:)
oooooooooooooo:p:D I saw it first by Hilbert over at Guru, but then did see your post Jh, excellent work:cool::D
Hmm just watched this.
And tried the download 64bit version and wow the demo is a lot nicer and far nicer frame rate than whats on utube. I guess the utube was console version which is why it doesnt look or feel as smooth as what i just saw from running the demo.
Btw might be a nice fraps benchmark this, ill see if i can figure out how to do the fraps bench and post back.
Edit - btw u might need the binaries for the demo there in the forum i linked to above a few posts down.
Code:
Frames, Time (ms), Min, Max, Avg
  8158,    156063,  28,  63, 52.274
No point benching this really as the engine is locked to 60 frames
Elements run with 24/7 clocks. No scaling with this demo so single card run.
4960 @ 4.5
Ref 780Ti stock bios 1110/1850
Elements does look good though, especially toward the end.
