^Placed right in the TitanZ thread. Proud of you Gibbo.
18 mhz overclock? I'm sure they could've at least gone to 1050 mhz. At least this comes with the briefcase though.
Still the 295 X2 is not really a card to overclock,
its more about a truly powerful gaming card and designed for 4k use which it does superbly well.
Not forgetting push pull on the rad.
I'd be slapping two Gentle Typhoon 1850 RPM fans on that rad if it was me. That would bring temps down into the low 60's - high 50's i bet.
I'm not sure if I would want to plug two GT's into the 295x2 as we don't know what power the header is rated for, but a second one could def be run off the mobo or a molex (mobo would be best as it would ramp up with CPU temp and GPU/CPU usage usually go hand in hand unless your mining).
I use these very fans a lot and using them in push/pull is not going to make a lot of difference to the temps - worse still if the 295 was overclocked a lot there is no way a single 120mm rad is going to deal with the extra wattage.
I use 6 Gentle Typhoon 1850 RPM fans on a 360mm rad just to cool a 3960X and even then things can get a bit warm.![]()
As Gibbo said this card is not really for overclocking, I think people should enjoy it for what it is - a superb gaming card.
Well technically speaking a single 120mm could cool pretty much any loop, it's just the noise form the airflow required would be unbearable. The one on the 295x2 still has a lot left in the tank as it's doing well with a single generic fan, a pair of GT's would def increase it's overhead.
That's a bit of a skewed statement, you don't mention what type of rad or what clocks your running the 3960X at, or what your definition of a bit warm is, tubing/rads are supposed to be warm. By comparison I have 3 Gentle Typhoon 1150 RPM fans on a 360mm rad cooling a 4930K and temps are fine, in that example 1850's would do nothing as the rad is low FPI so owuld see 0 benefit from higher RPM or push/pull.
To be honest if you have a high FPI rad and six GT1850's then any temp issue will most likely be down to the loop being unable to get the heat from the block to the rad fast enough, not the rad being unable to exhaust it.
All samples are different, a lot of review sites have gotten better overclocks from this card than from most R290X they have reviewed.
I use an AX 360 rad for that, all it has to keep cool is a 3960X which overclocked can use nearly 400 watts - a bit less than the 295x2 at stock.
Could you post the links please as I have not seen any reviews for the 295 where it has gone over 1100mhz on the core.
The rad is only cooling the cores of the 295x2 though the vrms are cooled by the large fan in the middle.
1135mhz - http://www.hardwarecanucks.com/foru...md-radeon-r9-295x2-performance-review-19.html
1120mhz - http://www.techpowerup.com/reviews/AMD/R9_295_X2/27.html
1120mhz - http://www.bit-tech.net/hardware/graphics/2014/04/08/amd-radeon-r9-295x2-review/10
Some other reviews are showing 1100mhz. This is all at stock voltage. 1100mhz is the core clock both of my 290's will do on stock voltage.
Nvidia could allow AIB partners to bundle better cooling solutions/ water blocks with their cards like Gigabyte did when they sold the Titan with the Titan cooler and their WindForce cooler also bundled with it.
GeForce GTX TITAN-Z Market Availability Delayed?
NVIDIA's flagship dual-GPU graphics card, the GeForce GTX TITAN-Z, was expected to go on sale later today. That launch is now delayed, according to a SweClockers report. The three thousand Dollar question is why. According to some sources, NVIDIA is effecting a last minute design change that sees a meatier cooler on the card, than the one Jen-Hsun Huang rafikied to the press at GTC 2014.
There may have been a last-minute realization at Santa Clara, that the card - as presented at GTC - may not cut it in the ring against AMD's Radeon R9 295X2, or at least it won't be able to warrant its vulgar $3000 price tag, against the R9 295X2's $1500; despite AMD's rather messy three-piece approach to its liquid-cooled product (the card itself, a radiator, and coolant tubing), and so NVIDIA could be redesigning the GTX TITAN-Z with an even bigger cooler, to facilitate higher clock speeds.
