Sleeping Dogs Bench Thread
Lol that run was stock :D
Edit: wait what score are you even talking about? Lol
Modified tess? :p
Dual gpu 1080P. Reckon i might have 5mhz more on the core in the tank if i need it. If it was colder the score would be higher i think. :p
No artifacts on these runs. Once i go past 1270 i do get a few though once temps hit the 80's. The problem i have is keeping temps in check. (shock horror :p)
My PSU passed the Sleeping Dogs burn in test at least. 1270 Watts pulled at one point from my Superflower plat 1000W.
[email protected]
290 Crossfire at 1250/1625
14.4 WHQL
1440P
Nice although in vain as I'll have better scaling now and can run 1300 core over two of mine lol. Or I could just disable world density as judging by some of the results some of you are : p
1270w? Christ... I'm afraid to put the watt meter on the trifire rig :D
That final scene made it reach that wattage. Crazy innit. :D
These reference cards can take it though. Its the only time i let them stretch their legs. Now they go back to -0.037v and -0.100mv @1050/1250 for 24/7.
Probably but still.
Kaap will get a performance boost if he runs two cards on 14.4 WHQL as well, so i expect he'll pull clear of me when he does. I'm bottlenecked at 1080P, need a 6 core then i could improve my score even more. Gpu usage did drop a lot during the 1080P run.
I didn't disable anything, so hope you're not saying i did. That's a legitimate run using the Extreme preset.
No, for the clocks used in comparison to your last run and drivers there doesn't look to be anything out of place lol. I was speaking about some of the other ones. should have kept the Lightning in, would have blazed Kaaps single card run :D
Lighting would be great for this bench i think because of its cooler and the Samsung memory. How i wish i could send my cards off somewhere and have Samsung memory fitted. Bet id see a 5% or more performance boost.
Have you sent it back already?
Quite a nice boost with these too :p
I'm having to run it three times and double check setting. might have to include a video for proof unless someone else runs this on the new NV magic drivers for a comparison lol
Kaap?
Bloomin eck! I was just having a dabble with benching this and looking at power consumption and here's what happens:
2600K @4.7 1.344v
7970's @1200/1600 1.244v = 655w peak
7970's @1260/1900 1.3v = 780w peak
:eek:
Either way, the game's playing funny buggers with me as it decides to CTD with no error message or nowt at the end of the first stage even at stock clocks... Ah, whatever.
2600K @4.7 1.344v
:eek:
Have you got frame pacing on or off.
Kaap?
Sleeping Dogs was one of the games that got a big perf boost on 337 so at 1080P id expect you to beat mine and Kaaps scores fairly easily. Might be closer at 1440P/1600P though. AMD cards are just too bottlenecked at 1080P but 337 improved this area for Nvidia.
I expected a boost, but :P
Can you re-run this on your Titans Kapitan for a comparison?
4960@ 4.5Ghz
Ref 780Ti @ 980/1750 (Stock bios)
Running a tight CL8-10-10-28 2133 for 24/7 at the mo so that might help in this bench, not tried it enough
Sometimes it can be unstable when benching with it turned off.
Yeah, true. Maybe there's something going in 14.4, as having it switched off worked fine with the 13.11 b9.5's I used to post results in here before...
Just tried it with FP on and it still does it.
735w @1250/1800 1.288v btw.
