Maybe it is your graphics card causing the issue?
Really? I am not sure a gcard can cause backlight bleed on a monitor pal...
I don't know, but logically you have been through several different types / brands of monitor with the same issue, which would suggest something else?
It will be the screen, there are threads about this monitor in the monitor section with people looking for ones made on specific dates that are less prone to this issue.
There is also a user at oveclock.net who took his apart and messed around with the USB PCB which is in the bottom left corner to help relieve pressure on the screen and it improved it a lot.
Just like to say excellent work OCUK, and that is one hell of a replacement![]()
Well not yet it's not. OP still doesn't have a fully working panel.
Fair play to OCUK for going above the order but again it raises the question, why in this case was the panel not checked before being given to the customer?
I appreciate all monitors can't be checked but sensitive cases like this need some kind of QC from OC.
I did check the monitor myself and there was not any back bleed. It seems like this has occurred as it was fine, and got worse from what BaDBoY_uK is saying. DELL are replacing the unit, so let's hope it is a monitor that finally works properly!![]()
Because quality assurance is down to the manufacturer, not retailer.
Update - just had a phone call - at 1pm - to say my monitor is out of stock and won't be delivered today
I am so unlucky
I am so unlucky
With your luck I'd never leave the house incase of a freak accident.
Feel for you dude I really do. Was going to come up to Eon at i51 but didnt. You going i52? Gonna have to give me a shout next time. Have a beer.![]()
