Recieved my apple pie from Scopes. Must say he has it spot on. I have been missing out!!
Also ordered blueberry and peach, can't wait to try them. He also threw in a 10ml bottle of berrylicious!
The little handwritten 'Hi Bill, thanks ATB, Si' on the invoice finished off the whole thing rather nicely. Highly recommend this website: http://www.scopesejuice.co.uk/
Off to email him now!
Just received my order too, had a bonus of 5ml of Banana in there along with my order of Peach, Apple Tart and Berrylicious![]()
Hope you went for the apple tart first!!
Let me know how the banana is if you don't mind, I was in two minds about that!
Hmm, but it'll take sveral days before I can vape them and I'm almost out of tiger stripe and have no other 6 or 8mg juices to vape.
Lol, unbelievable, tons of juices here and none at the right nic level. Anyone know where I can buy decent low nic juice ready to vape?
Check your trust
Hi Merlin, did you reply as i cant see anything lol
If you cut the ejuice with VG you are going to lose flavour.
iirc, you will need to decant the 10ml bottle of juice into a 20ml bottle or a cup.
Then add 10ml of pg/vg, as you are doubling the juice, you are halving the nic content.
So you will lose 50% of the flavour.
The best way is to buy some 0% nic version of the juice you want to dilute.
then mix the 2 x 10ml together, this way you are halving the nic but keeping all the flavour
Hi j.col, just replied yea.
I'm sure you're right. Only reason I was considering adding VG was because someone on UKV said to me "mix some VG or PG with it to thin it down a bit, you will hardly notice the difference in flavour and more juice to consume, 2.5ml pg/vg to 10ml of 12mg juice will take it down to 8mg juice"
Got it.
I may be wrong here, but usually if you are halving a nic strength, you will need to double what you started with, eg. 18mg to 9mg.
It gets a little more complicated with 12 to 9mg.
But using the ejuicemeup nic combine feature, to dilute 12mg to 9mg, you will need to add 3.3ml
to 8mg you will need 5ml of pg/vg
am after something a bit weird and wonderful, preferably of a fruity nature.
If she is not in a hurry, try this Nemisis clone http://www.fasttech.com/products/0/10005773/1448300-nemesis-style-mechanical-mod
Then you can but different colour tubes for it http://www.fasttech.com/products/1411/10005773/1647200
Its a very good mech mod clone, from the reviews its as good as the oroginal
