Thanks for the help.
I will try that sequence, I presume I would flash the bios between 4 & 5 ?
I had pretty much done it using DDU, maybe not that exact sequence.
The cards are HIS Ice Q Boost.
Thanks for the offer of editing the bios for me that much appreciated.
Is that the copy GPU-Z makes and calls Tahiti by default as I thought that was the stock bios that does boost ? Or have I got the wrong end of the stick ?
Thanks again.
For the Copy of bios, follow these steps
1. Flash the NON-BOOST BIOS (Follow steps in previous post)
2. Once you've successfully flashed the Modded BIOS with no boost, make a copy using GPU-Z.
3. Put the BIOS in Winrar or 7zip (It just protects the file)
4 Send it to me and tell me what clocks, volts and what custom fan profile you would like.
REMEMBER to follow step by step
