Just picked up an inexpensive Crucial C300 RealSSD 64Gb from here in the MM. Plan is to drop a fresh install of Windows 8.1 onto the drive to have a play around with it before deciding whether to jump from the W7 install on my current SSD which is an OCZ Vertex 2E.
Having done a bit of digging on the C300 I have a couple of questions.
Motherboard is an Asus P6x58D-E. Should I plug the C300 into the SATA6 or SATA3 ports? Am I right in thinking the SATA6 ports are Marvell ones? What is the procedure for installing using the SATA6 Marvell port, do I need to change anything in my BIOS? Anything else to be aware of? Also, I've read that you should download the manufacturers SSD tool and carry out a 'full erase' prior to attempting a Windows install? Lastly, whats the score with 'garbage collection' on the C300?
Thanks in advance for any assistance.
