About to setup a new Dell machine with a new WD 1TD Blue (WD10EZEX).
A warning note in the Dell box says special steps are required froa 512e hard drive?
It then goes on to suggest if it is a 512e drive special drivers need to be installed yada yada.
Anyone able to clear this up/comment?
The industry is transitioning to Advanced Format on 3.5” drives beginning January 2012.
Use Intel Rapid Storage Technology (RST) driver console to verify whether the drive is Advanced Format or not. The Intel Rapid Storage Technology driver must be revision 9.6.0.1014 or later and all the latest updates for the Windows Operating System must be installed from Windows Updates.
Click Start, Programs, Intel, then Intel Rapid Storage Technology.
Click the Manage icon.
Click Advanced and then click the desired drive.
If the physical sector size is 4096 bytes, it is a 4K hard drive.
If the physical sector size is 512 bytes, it is a regular hard drive.
If both the physical sector size and logical sector size are 4096 bytes, the drive is a native 4K drive.
