**ALWAYS WANTED A SUPERFLOWER LEADEX PSU BUT PUT OFF BY THE PRICE? WE HAVE THE SOLUTION!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We were aware that so many of you really wanted a Leadex PSU from Superflower due to the unique features such as the patended white LED connectors that really set the look off making the PSU actually one of the main focus points in a system. Previously the Leadex were only available 1000W upwards with a Platinum rating which obviously carried the price tag associated with such a high-end high wattage PSU. Now however we have new models of Leadex, same quality, same outstanding reliability, same ECO SILENT fan mode and of course those lovely glowing white LED connectors and now available from just £79.99 Inc. VAT.
Check out the Leadex range here:-
SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black @ £79.99 inc VAT
Leadex series PSU are 80+ Gold certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Ledex series PSU provides high efficiency & stable power output and come with a 14cm two-way thermal control intelligent cooling fan to ensure your professional PC system will work under heavy load, also capable of powering your PC system equipped with NVIDIA® SLI™ or ATI CrossFireX™ setup.
Features:-
- 100% Full Modular Cabling Design For Easy Cable Management
- 80 PLUS ® Gold Certified, 90.43% 92.03% 90.27% Efficiency At 20% 50% 100% Rated Load
- Full Range Auto Voltage Detection Design 100V~240V (Active PFC)
- Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
- Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
- Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
- Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
- Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
- Patented Easy To Use & Install Crystal Clear Cube Connectors with LED
- More than 2,000 times On/Off test
- Unleaded Green Materials with RoHS/WEEE Compliance
- Perfect For Professional & High Performance Gaming System
Speciication:-
- Type: ATX
- Maximum Power: 650W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable: Yes 100% modular cable design
- Input Voltage Full Ranage - 100V~240V
- Input Frequency Range 50 ± 3 Hz / 60 ± 3 Hz
- Output +3.3V@22A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- Protection OVP?OCP?OPP?SCP?UVP
- Dimension 200mm(L) x 150mm(W) x 86mm(H)
- 1x 20+4-Pin ATX12V/EPS12V
- 1x 8-Pin EPS12V
- 1x 4+4-Pin ATX12V/EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £79.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 750W Fully Modular "80 Plus Gold" Power Supply - Black @ £99.95 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 750W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Output +3.3V@24A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 4x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £99.95 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black @ £119.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 850W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £119.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1000W Fully Modular "80 Plus Gold" Power Supply - Black @ £139.99 inc VAT
Features:-
Speciication:-
- Type: ATX
- Maximum Power: 1000W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £139.99 inc VAT.
ORDER NOW
SuperFlower Leadex GOLD 1300W Fully Modular "80 Plus Gold" Power Supply - Black @ £155.99 inc VAT
Features:-
- 80 PLUS ® Gold Certified, 91.09% 91.75% 89.25% Efficiency At 20% 50% 100% Rated Load
Specification:-
- Type: ATX
- Maximum Power: 1300W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- Modular Cable Yes 100% modular cable design
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
- Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=367
Only £155.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - Black @ £149.99 inc VAT
Leadex Platinum series PSU are 80+ Platinum certified with 100% fully modular cable design, our R&D team's latest innovation, a brilliant idea to maximize PSU cables & connectors management to have the best cable routing solution, also increase case chassis air flow to have best cooling for your system.
Features
- 80 PLUS ® Platinum Certified, 91.12% 92.53% 91.11% Efficiency At 20% 50% 100% Rated Load
- Product Review: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=340
Specification:-
- Type ATX
- Maximum Power 1000W
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- Output +3.3V@20A ; [email protected] ; [email protected] ; [email protected] ; [email protected]
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £149.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White @ £149.99 inc VAT
Features
Specification:-
- Type ATX
- Fans 1 x 14cm
- PFC Active
- +12V Rails 1
- 1x 8-Pin EPS12V
- 6x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - Black @ £179.99 inc VAT
Features:
- 80 PLUS ® Platinum Certified, 91.07% 92.44% 90.47% Efficiency At 20% 50% 100% Rated Load
Specification:
- Type: ATX
- Maximum Power: 1200W
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
Only £179.99 inc VAT.
ORDER NOW
SuperFlower Leadex Platinum 1200W Fully Modular "80 Plus Platinum" Power Supply - White @ £179.99 inc VAT
Features
Specification:
- Type: ATX
- Fans: 1 x 14cm
- PFC: Active
- +12V Rails: 1
- 1x 8-Pin EPS12V
- 8x 6+2-Pin-PCIe
- 10x SATA
- 5x 4-Pin-Molex
- 1x Floppy
- Warranty: 5yr
ORDER NOW
Also do not laugh but here are some photo's from my own personal home PC which has a 1000W Platinum white model in it:-
IMG_3564.jpg~original
IMG_3566.jpg~original
IMG_3565.jpg~original
IMG_3561.jpg~original
IMG_3562.jpg~original
The quality and reliability is well proven and is why our systems are built and powered by Superflower power supplies, great reliability, unique features and over-engineered for near silent operation and the lowest electricity bills. :)
id add images of the cables. all just show the psu ;)
You can see the cables in my images as I don't understand the meaning of cable tidiness. :D
But they are braided for the PCI-E cables and flat for the periphals, actually very nice cabling indeed. :)
Buy one you must! ;)
Hmm nice atm am looking for one which would be best for what i have in my sig, both the graphics carda at stock speed can`t overclock them cause of my psu.
I probably want a little bit extra power also thinking about going fully under water in next few months.
I'd go with the model I have which is the 1000W Platinum white, you can see my pics of it above in the OP.
When it comes to PSU's you won't find a sexier unit and they back up those looks and bling with some of the best reliability being out there and of course it is pretty much SILENT. The only thing I can hear in my system is the Corsair fans which are running at 7v, that is how quiet the PSU is, in ECO mode I have gamed for hours and the fan does not even spin, only ever seen it spin when on a hardcore benching session. :D
Amazing price on 1200 Plat Gibbo. So stable that PSU.
Moved it into 8Pack builds as standard.
Managed to ran 4 290X all overclocked to 1200+ 1675 and CPU at 6.2 on one of those PSU no problem.
Yes it is a great achievement. As I have said before the 1000W and 1200W Platinums were actually engineered to be sold as Titanium specification, but unfortunately at the time Titanium specification was not a certified standard and as such they were classed as Platinum.
This is why the Superflower 1200W can do feats which other 1200W units cannot accomplish. :)
Cracking price on the 1000w gold model. In need of a new psu for when i go sli. Wouldn't trust my corsair hx 850 as its getting on a bit now.
£10 more gets you a Platinum that was engineered to meet Titanium grade, I'd buy that. :)
Oh wait, I did! :D
Hi there
Also here is a collection of all the reviews in the last 12 months from around the world, check them out:-
Reviews links (marked by countries):
http://www.cowcotland.com/articles/1413/test-alimentation-super-flower-amazon-550-watts.html [FR]
http://www.gamezoom.net/artikel/Super_Flower_Golden_Green_HX_650W_Test_Review-29797 [DE]
http://www.hartware.de/review_1721_6.html [DE]
http://www.overclocking-pc.fr/index...lower-430w-golden-silent?showall=&limitstart= [FR]
http://www.techpowerup.com/reviews/SuperFlower/SF-1300F14MG/ [US]
http://www.overclocking-pc.fr/index...s/417-test-super-flower-650w?showall=&start=4 [FR]
http://mod-your-case.de/index.php?forum2-showposts2-477 [DE]
http://awardfabrik.de/10-netzteile-bis-650w-im-roundup/17/ [DE]
http://www.tweaktown.com/reviews/57...m-1000-80-plus-platinum-psu-review/index.html [US]
http://www.techpowerup.com/reviews/SuperFlower/SF-1000F14MP/ [US]
http://www.ocaholic.ch/modules/smartsection/item.php?itemid=1067&lang=german [DE]
http://www.kitguru.net/components/p...uper-flower-leadex-platinum-1000w-psu-review/ [UK]
http://www.gamezoom.net/artikel/Super_Flower_Leadex_Platinum_1000W_Test_Review-30284 [DE]
http://www.technic3d.com/review/net...dex-platinum-1000-watt-netzteil-im-test/1.htm [DE]
http://www.overclocking-pc.fr/index...tion-super-flower-sf-1200-leadex-80-platinium [FR]
http://www.techpowerup.com/reviews/SuperFlower/SF-1200F-14MP/ [US]
http://www.insidehardware.it/hardwa...tinum-1200w-prima-recensione-italiana#content [IT]
http://www.tomshardware.de/SuperFlower-GoldenGreen-80-Gold,news-245409.html [DE]
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=367 [US]
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=370 [US]
http://www.gamezoom.net/artikel/Super_Flower_Leadex_Gold_750W_Test_Review-29834 [DE]
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=340 [US]
http://www.techpowerup.com/reviews/SuperFlower/SF-500P14FG/ [US]
http://www.modding.fr/?p=14286 [FR]
I have the 1000 Watt Black Superflower PSU and it's so quiet. I love it. This power supply puts Corsair's PSU's to shame.
Worth every penny.
