***The Vapers Lounge***
Status
Not open for further replies.
Here's my two favourites. Provari mini with kayfun mini on the left and Nemesis with taifun on the right. I highly recommend both these atomisers.
Save yourself a ton of money get a nature vape coil or 1 of their tanks with coils, fantastic vape and last forever (seemingly). been using these for about 12 weeks, never missed a beat, cllass
Getting real fed up of the coils on my Mini Protank 3, I've bought three packs since I got it a while back, the original coil that came with the tank lasted ages, but all the others since have been crap after a few days with little vapour output. All from different vendors too so not even a dodgy batch - though one set had the small head, and the others had the longer stemmed bit over the coils.
I think that is the main reason so many of us end up with rebuildables. You think you have found a good one then you get a load of rubbish coils. I don't know why but it seems common (well has happened to me loads of times) but the first set of coils are good then everything after isn't.
Thanks for that, I've ordered a couple to try out. How long would the coils themselves last? Obviously you can re-wick them but does the coil itself eventually die?
They are micro coils so will last for weeks if not months
If you want to change flavour, remove the old cotton, give tank a rinse with warm water, dry it with kitchen roll.
Dry burn the coil to remove all the crud.
Put new cotton threw coil.
Put a few drops of new juice onto the wick to get it started.
then just fill tank
Looking to sink about 50 quid into juice as I'm fed up of buying odds and sods all the time, what's the best value for money (quantity) vs quality?
I'm thinking yaeliq the obvious choice? I say that as the vast majority on UKVT on Facebook seem to have no issue buying huge amounts of it!
I expect making my own will see much better value for money but im in a house share for a couple more months until contracts are exchanged on my pad and don't really have the space to do so.
Without being disrespectful to fellow UKVT group members, the majority often appear to jump on the current cheap juice bandwagon, a little too readily.
I've learned to take opinions of flavours with a pinch of salt - one man's Poison Being Another's all Day vape...
I choose to buy quality over quantity - Scope's Apple Tart, Accie's Ambrosia, Digby's Mum's Custard, Snake Oil etc.
Yaeliq has some good flavours, fantastic pricing, but they all require a good couple of weeks steeping - same goes for JooseJuice, 60ml for £10.25 delivered, last time I checked.
Be Your own judge.
500ml PG - £5
500ml VG - £5
100ml Nicotine - £15
Mixing supplies - £10
5 x flavour conc - £15
£50 for about 10x as much juice as you would get pre made.
500ml PG - £5
500ml VG - £5
Hi NirK,
Sorry for asking you to teach me to suck eggs, but what quantifies 'mixing supplies'?
I assume some pipettes/syringes, large mixing bottles...and plenty of wet wipes/kitchen towel :p
Otherwise, assuming you've mixing experience, where would you suggest getting the above from?
Hi NirK,
All you need is some 1ml / 2.5ml syringes, some 10ml bottles and a juice calculator really. Variety of concs and PG from chefs vapour / ebay or flavourart, DV, T juice etc. nicotine from cig-eliquid, VG from boots £1.50 200ml. For convenience pre made liquids, but for cost DIY is so much cheaper, about 25% of the cost. Also you can customise it exactly how you want, I use 70/30 16-18mg strength, but if you wanted you could have anything, most pre made you are stuck with 70/30 12 or 18mg. That amount would make you 33 x 10ml bottles (only the nicotine would run out first, everything else would last longer) at £5 a bottle pre made that would cost you £150.
Thanks NirK, legend! You've swayed me, DIY mixing, here I come! :p
Expect a few **** ups and some wasted liquid, also takes a bit to find some concentrates that you like, but when you have it sorted out then it is much better than buying pre made. Use different syringes for PG/VG, Nicotine and concentrates.
Where'd you pick that up from man? May pick up the Hana Modz clone soon(ish).
I got it free as a sample direct from the manufacturer.
I do have a lot of them on order mind you (with full Hana modz logos like the pics below)! First batch is expected on the 22nd May.
I'm only going to be selling them in black (which I think will be the most popular by far) and some silver versions as well. Wont be bothering with the girly funky colours!
Fantastic bit of kit.
Once you find your all day vape, I recommend getting a 25ml measuring cylinder (like a quid or two) for mixing up bigger batches of your regular juices. Good for liquids that need a week or two to steep like vanilla custard.
Status
