**ALWAYS WANTED A SUPERFLOWER LEADEX PSU BUT PUT OFF BY THE PRICE? WE HAVE THE SOLUTION!!**
I doubt you would notice any difference in power consumption between a Gold or Platinum unit.
Tbh the whole 80+ system is a big con anyway.
These are great PSU's and superb value for money.
I didn't mention power consumption and that's not the reason for wanting a platinum rated PSU ;) It is a good side effect though in a few ways.
I agree these are good PSUs (I wouldn't be interested otherwise).
The sweet spot for efficiency is 50% load, a 650W Gold ran at 50% load will probably be more efficient than a 1000W Platinum ran at 30%. The trick is to pick the wattage which is closest to twice your load power draw becasue that's where you get the most efficiency and the most benefits as a result of the efficiency (less heat, noise, power consumption).
I have found with a fanless or semi fanless PSU (I've owned both), you get heat soak in the PSU that then radiates into the case. Which increases system temps and noise becasue the case/cpu fans need to idle at a higher rpm.
A more efficient PSU reduces this heat soak and choosing a wattage closest to your usage helps to take advantage of the efficiency potential.
Idealy I'd like a 650W Titanium PSU with a fan profile that is continuous but idles at a very low RPM so it's silent but stops heat soak and then ramps up when needed. The Titanium rating also offers high efficiency at 10% load so you get high efficiency all the time, both during idle/light load and under load. Which all helps keep the heat and noise down in the whole system.
It would also be good to be able to customise the fan profile in the PSU, with it being able to overide your profile should it need to. You'd then be in complete control of the heat/noise ballance.
If you just use your system for gaming and it's only on while your gaming them all this doesn't matter of course. If it's used all day much of that idle/light load and your trying to keep noise down, efficiency and more to the point the effective use of that available efficiency is important.
Totally agree with this.
I have a number of Seasonic X series PSU's sitting in Silverstone Fortress cases that are rotated at 90 degrees, so the PSU sits above any components. Also there is air coming up the case that's cooling the PSU casing. The fans on my X series never spin, there is no dust collected on the PSU intake filter. I put part of it down to the case the Seasonics are in, i'm sure if I was using a regular case the Seasonics would heat up more.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-168-SV
Just received a 650w version for a build. Looks nice and well built same as larger models.
No UK power lead included which is no issue to me as I have draws of them but might be to some.
Decided to use the Superflower in my build as my 850w Be-quiet is overkill for my system. Running the elemental demo the fan never span up and even at auto it's practically silent. It looks pretty too with it's lights.
Really nice PSU.
1000w in a 250d why ?
My 4.6ghz 4770k and 1250/3800 780Ti only pulls under 400w. You getting ready for a Titan Z....:)
Yeah at 20-40% the 1000W runs the highest efficiency so thought overkill would be ok :)
And yeah defo dont fancy having to upgrade my PSU anytime in the future regardless of what GPU i might want (or need) :D
Really nice PSU.
That looks stunning!
Looks like the platinum model is out of my budget, wages havent cleared yet so ill miss two deal. Gonna go for the gold rated 1000w version. Besides, whats a few quid here or there in leccy over the course of a year. Aka turn off a few other appliances.:D
Well i went for the 1000watt white Platinum thanks to gibbo it will go nice with the 600d case i got here last week nice Green lights from the fans in the new case and the white lights from psu :P celtic man i am lol. Am hoping now i can overclock both my new cards.
No doubt they would, mine sits at the bottom of the case and I had to add a fan to the side panel to cool my TV card which is directly above it, otherwise it would overheat and cause pixelation on recordings.
Off thread topic!
I don't understand why more manufactures don't make cases that rotate the board 90 degrees. The rotated Silverstone cases have the most efficient cooling as all heat flows upwards with no dead cooling spots. Also unlike a tower the heat from cards can't be absorbed into the card above.
BTX and 1 other (cannot remember name but its was AMD's, was it DTX) and Illegitimate BTX (the upise down cases with Mobo on opposite side has been tried and failed.
Also some Mobos/Heatsinks did not have wicks in Heatpipes so they ran hot as they relied on mavity.
