*** The Official Diablo III Thread ***
Status
Not open for further replies.
So,post patch...what`s the "To have" gear for crusaders? Same as before, or do the changes favour something else.
Pretty much all weapons are now viable and depend on how you want to play, Darklight 1h is great, Golden Flense, Fate of the Fell, Maximus, Blade of Prophecy, Gryfalcon etc etc etc.
All weapons are great, it depends on playstyle, there is no must have weapon now, all have pro's and cons.
Find a build that suits your playstyle and gear for it, not the otherway round, which is how it was til now pretty much.
Servers are up :)
Do like the %damage fix!
Nice, might make that Natalya's I found the other night a bit more competitive.
My Manajuma's knife has not been changed on my character profile page yet, but it had poison damage and +9% so I am hoping it will get from 2270 DPS to closer to 2400~.
My TF on my wiz has +6% IAS - I am wondering whether +10% dmg would be better here?
For anyone who can logon, are the source/offhand dmg ranges much increased now? they said it was a retrospective fix.
Yeah my legendary offhand on my wizard has gone up around 60-70 dmg more....gained 60k dmg on char sheet.
10% damage should be better than 6% attack speed on a weap.
Goddamn, still no Calamity for me :(.
I've got Danetta's set, but I just don't like it. The (2) piece just leads to me dying more as I can't vault away.
You mean because you are hatred starved? Use Preparation:Punishment to convert discipline into hatred in that case but its very very rare I dont have enough hatred to vault away when using Danettas.
Assuming you have a cindercoat and a decent amount of paragon into resource cost reduction then a trail of cinders vault is costing about 5 hatred..and you regen 5 hatred per second naturally.
I have a lot of time for Danetta's set, in fact once a rift guardian is dead I switch to them and vault around the maps cherry picking the elites and goblins. I also use them exclusively for bounty farming. Best i've found of each so far though are 2.5k examples that I have had to roll sockets onto so they arent up there with my Calamity and Nat's combo for raw damage, but they are close enough.
Dunno why people are getting so butthurt over a fix to what was clearly not intended with regards to Blessed Shield - Shattering Throw when using Gryfs and Jeka. Move on and try something new, if you cant get over it then maybe Crusader is not for you, try one of the other classes.
The amount of whine that has come from the Blessed Shield change and Rally change is insane, i use a Blade of Proph and have 4 pieces of Akkhans so was nearly at the point of the BoP Spam, but i see this patch as setting me free from having to rely on 2 weapons to perform at endgame and instead opening up more variety and choice for endgame
Looking forward to trying out seismic slam instead of HOTA on my barb. Pre level 70 I found a 2H that reduced fury cost for ss so I used it for a while and had great fun with it.
I had that weapon while leveling 60-70 and it made seismic slam awesome. I have been trying out a leapquake build, but I am not really sure if I like it. I might try a more fire based Call of the Ancients build.
Depends on your build, attack speed is important for proccing things like fetishes for WD. If you rely on high damage crits and what not then probably damage % reroll.
HotA barb, so high damage crits are indeed my slice of pie. I'll try to reroll for 9/10% damage increase and see how it goes. Already at 1.5m reroll though so I'll lube up first.
Ah yes, the ever increasing cost of rerolling an item. I think my IK gloves are at 1.5m as well. Still, at least it should be a little better now that all three rolls can't be the same affix.
Status
