15 May 2014 at 20:44 #1 NeilF NeilF Soldato Joined 15 Nov 2003 Posts 14,477 Location Marlow So Windows Update is offering me Silverlight to download. Do I need/want it? I do not use IE, only Firefox.
15 May 2014 at 20:48 #2 imb4tman imb4tman Associate Joined 14 Jun 2010 Posts 1,431 Location Clevedon Its used for Netflix and Amazon Instant and probably some others. If you use them get it, otherwise not much point.
15 May 2014 at 20:56 #3 NeilF NeilF Soldato OP Joined 15 Nov 2003 Posts 14,477 Location Marlow imb4tman said: Its used for Netflix and Amazon Instant and probably some others. If you use them get it, otherwise not much point. Click to expand... Netflix etc? Not on the PC in question, no.
15 May 2014 at 21:21 #4 KIA KIA Man of Honour Joined 14 Nov 2004 Posts 13,884 Don't install it for the sake of it.
15 May 2014 at 22:04 #5 MissChief MissChief Caporegime Joined 17 Jul 2010 Posts 27,252 Also required for Sky Go if you use it.
15 May 2014 at 22:23 #6 NeilF NeilF Soldato OP Joined 15 Nov 2003 Posts 14,477 Location Marlow MissChief said: Also required for Sky Go if you use it. Click to expand... Nope... Just a basic browsing/document PC...
16 May 2014 at 08:36 #7 demonix demonix Associate Joined 26 Jul 2008 Posts 2,100 Location Cowley, Middx Only if you use a site that requires it, so if you don't then just de-select and hide the update. Also silverlight works with a majority of browsers, not just IE.
17 May 2014 at 18:20 #8 TheVoice TheVoice Soldato Joined 15 Aug 2005 Posts 23,554 Location Glasgow You'll know if you need it because any sites or services you use will be asking for it.
17 May 2014 at 18:33 #9 Tute Tute Soldato Joined 24 Jul 2004 Posts 22,592 Location Devon, UK TheVoice said: You'll know if you need it because any sites or services you use will be asking for it. Click to expand... This. I use Sky Go, Netflix etc. on my PC so I do need it. But I wouldn't install it for the sake of it.
18 May 2014 at 14:32 #10 Twirlywoos Twirlywoos Permabanned Joined 8 Jan 2010 Posts 10,263 Location UK I need it for 3d vision
