FIFA 14
Redstar you seem to play at complete opposite times to me. I tend to be on the evening and you are in during mid day. At the moment I am in the process of trying new teams and formations again so will be fielding weakened teams ;) sometimes things can go badly wrong as I experienced last night :(
Been on pro clubs more again recently. Up to 88 rated as a fat 6 ft lad. Could get a lot higher if I went shorter and slimmer.
Quite fun even though the usual FIFA frustrations apply. It helps that the majority of people playing Any are BAD.
team is playing a lot better subbing Robben on for Di Maria and Silva for Pepe, tried that tots Ligue 1 LB, Bedimo I think it is, he's very good.
Had my first game back on FUT last night for quite some time probably 2 months + with just my rubbish BPL team after i sold up. Won but it was terribly laggy, ended up coming off shortly after.
We all had laggy games on pro clubs last night.
EA must still be running DOS, they are badly needing to upgrade them.
They finally upgraded BF4 servers after 6+ months of complaints that they were terrible.
ps3ud0 is gonna join us for pro clubs soon hopefully. :D
See what he's about. I've heard only stories of awe and bewilderment about his skills so I'm expecting great things :D.
If you can dribble, you'll fit in really well. We generally don't hit many over the tops. Most of my goals come from me skilling past about 4 players or making a run for a ground pass from our Any :(. Hitting over the tops makes it quite easy at times if you time them so the defender spacks out.
I think I averaged 3 goals a game last night it was pretty comfortable.
Can I join in? I have to level up my pro first though right?
Don't see why not. :)
I'll just make a new club most probably.
Our two key traits when we play are dribbling (including skilling) and quick, short passing. Normally then I just get fed and I score but with two more players we can vary it up a bit.
I do like dribbling in pro clubs because as I mentioned before most people are just DIRE at defending it. It's not uncommon to rainbow over slide tackles and sombrero flick over the onrushing noob. :D
I used to be pretty good at over the top balls - far better at passing than skilling though - dont expect much...
Im only a 86 rated ST/88 rated CAM
ps3ud0 :cool:
We play 4231 so 2 wide CAM spots open :p
Nothing wrong with over the tops per se - more the endless spamming of them but I can't imagine any of you fellows will do that :D.
Edit: oh and my pro is pretty monstrous in the air so anything dinked in is gratefully appreciated :p.
