BT is the worst example of indian call centre support ever. Yesterday, I called to arrange a return/replace RMA style for a faulty BT Home Hub router. The indian web chat man insisted I talk to the call centre people. He didn't hand over the call properly and just dumped me at the other end. The UK call centre man was helpful, but the wrong department to talk to. He transferred me back to the indian call centre and attempted to hand over the case properly. Unforunately, the man at the indian call centre end was absolutely awful. He wanted to do a line test (I wasn't complaining about the line). He fiddled with my WiFi channel settings (put them back to automatic, yeah I know about channels) even though i expressly withdraw consent from him to do so. He declared 'because his remote tests did not show a fault, he was unable to arrange the replacement'. Bull ******* ****. The problem I was describing was a local area network problem - the WiFi interface, particularly on the 5GHz radio, was freezing up and dropping packets for no reason. This would never show up on his tests, and i hate him very much.
A month ago, I had a mouse chew up my internal wiring for bedding. After fixing the wiring, the downlink was capping at 200k (uplink 1MB) because the mouse chewing had obviously caused fluctuations and interference on the line and the cyclical downgrading stabalizating capping had kicked in. I knew exactly what the problem was, and what they needed to do to fix it.
*Indian accent*
Before i can proceed with the case sir i need to run a line test. Ok there are no problems with the line sir. Before i can proceed this case sir i need you to plug your router in to the master socket. Ok there are no problems with the master socket sir. Do you have a spare filter sir (these virtually never go wrong). Ok i need to assigned an engineer to this case sir (its thursday). Will you be in monday morning sir? (Literally, a switch flipping fix to remove the cap and let the line stabilise, 4 days )
Its God Damn hoops in hoops from a script when as a trained computer engineer I have told them exactly what the god damn problem is.
BT customer support is consistently the worst customer support I have received from any utility company, ever. The script monkeys that staff their call centre literally explode if you try to walk them off script.
