** TABLET CLEARANCE SALE: EVERYTHING MUST GO!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We shall be ceasing to sell tablets, as such we are selling off everything pretty much at half price, lots of great deals to be had on both new and B-grade.
Check them out here:-
http://www.overclockers.co.uk/productlist.php?groupid=959&catid=1882
http://www.overclockers.co.uk/productlist.php?groupid=595&catid=2689
A lot of silly deals guys, we want it gone so the pricing is stupid, ONE PER CUSTOMER and we won't be buying any more so if you buy more than we have in stock you aint gonna get it.
Some of the prices are iffy but you can tell there's been drops, that Nexus 7 2012 is 200 quid? You can buy the Nexus 7 2013 for that price.
Vivotab has had a massive reduction, but it's only been reduced to the price that it should have launched at (That's Asus/Microsofts fault though, and I bet they're not going to support you with a price that the market has dictated for it ; Surface 1 pricing, the original Surface 1 64GB comes in at 260 from MS direct (Even though they've just mispriced their Surface 32GB and put it from 230 to 280 :confused:) with superior build quality etc.)
Hi there
Uploader was stuck, only some prices went down, rest will update in a minute or two. :)
This for the money:-
Archos Platinum 97 9.7" 8GB IPS Tablet PC - White/Silver @ £129.95 inc VAT
ARCHOS is proud to release a new tablet in its ARCHOS ELEMENTS range: The ARCHOS 97 PLATINUM HD. One of the first Android tablets to reach the spectacular 2048 x 1536 super high resolution and powered by a powerful eight core graphics processor. Its blazing IPS screen delivers astonishing details, sharper texts and true vivid colors.
To get the smoothest interface, ARCHOS has equipped its tablet with a fast Quad-Core processor @1.2 GHz. Combined with the optimized mobile operating system Android 4.1 "Jelly Bean", discover all the possibilities of the ARCHOS 97 Platinum HD.
With such an impressive display resolution (2048 x 1536) the ARCHOS 97 Platinum HD delivers true vivid colors, sharper text and you will see every details of your pictures. The screen resolution is so high that its 9.7" panel is able to display 1 million pixels more than your 47" Full HD TV!
This amazing screen technology means that your HD videos and photos will always look bright and sharp. And, thanks to its IPS panel the 97 Platinum HD has wide viewing angles to make sure that you can share your tablet experience in every situation.
Specification:-
- Processor: AllWinner ARM Cortex A7 1.20GHz Quad-Core powerful processor
- Graphics: PowerVR SGX544MP2 Eight Core 3D Hardware Acceleration
- Display Screen: 9.7" Super Resolution 2048x1536 IPS LED Backlit screen
- Operating System: Andoid Jellybean 4.1 /w Playstore
- Language: Multiple language support (English Default)
- Memory: 2GB DDR3
- Storage: 8GB NAND Flash (Upgradable to 64GB /w SD Card)
- BBC Iplayer / Netflix compatible
- Memory Card: Micro-SD (Support upto 64GB)
- G-Sensor: Yes
- WiFi: IEEE 802.11b/g/n 2.40GHz wireless network
- Touch: 10 points Capacitive screen
- Mini-USB Port
- Video Decode:AVI H.264, DIVX, DIVX, XVID, rm, rmvb, MKV?H.264, DIVX, DIVX, XVID), WMV, MOV, MP4?H.264, MPEG, DIVX, XVID), DAT?VCD), VOB?DVD), PMP,MPEG, MPG, FLV?H.263?H.264), ASF, TS, TP, 3GP, MPG etc.
- Music Decode: MP3,WMA,MP2,OGG,AAC,M4A,MA4,FLAC,APE,WAV
- Picture Format: JPG, JPEG, GIF, BMP, PNG
- Camera: Front 2.0M/Rear 2.0M
- Stereo Speakers for improved volume
- Battery: 8000maH / 3.7v
- Battery life: 8-10hrs
- Dimensions: 240mm x 184mm x 9mm
- Weight: 640grams
- Warranty: 1yr
- Software update: Updates can also be downloaded at www.archos.com
Only £129.95 inc VAT.
ORDER NOW
Quad CPU
PowerVR 8 Core Graphics
2048x1536 IPS screen
Those are great tablets and at this price its nearly £100 off. :)
This is perfect timing, I'm looking at getting one for my daughter. If I was to get an OCUK one, how would the warranty work once you stop selling them?
if your buying new then I guess it will still be the same as any other retailer 12 months with them and then the manufacture if advertised longer then 12 months.... it just may take longer for OcUK to issue a replacement as they will have to order a new one under RMA when you send your's back and wait for it to turn up themselves before sending on to you, if buying B-Grade its 90 days and that is it ball's in your court fella..
Nice prices, my mums after a tablet. Ill guide her through a few options tomorrow if they aren't all gone.
