Any final things I should try before sending my GPU back?
18 Apr 2014
Quick rundown:
after downloading drivers the card worked.
after restarting my pc I had no display and switched back to mobo.
after uninstalling/reinstalling drivers the card worked again.
after restarting it stopped again.
I checked the bios - everything looked like it should've been working - so I disabled the intergrated graphics to try that; nope. I had to remove the battery thing (reset the cmos?) from the MOBO to get any display again.
After this, I called up and I was given 28 days to send the card back. as i've been busy i've delayed it for a while but I guess I need to do it soon... any other human error it could've been ect? everything is plugged in properly, in the right pci slot ect... any advice would be appreciated. thank you!
GPU: MSI r9 280x
MOBO - z87 HD3
Try it in another pc if available.
Make sure you remove the integrated drivers before installing the amd drivers.
theres something in the bios about legacy but I cant remember exactly,you set it from uefi to legacy
also try with the backup bios switch position on the graphic card
Error code 43? Usually means a bad PCI-E slot or bad GPU. I had to RMA my card for the same reason.
hmm. it was under device manager and had a little message saying windows had disabled the device. now that message isn't there... hmm. I'll see if it works now (no idea why it would've changed though). If i remove the intel drivers will I get no display if the GPU is still not working?
