Get a friend to run you through higher level difficulty (I believe this works) or if you have an alt - find a 2000+ weapon & re-roll any with reduced level requirements till it hits about 28/30.What's the fastest current method to solo level a character? I've got a level 28 Crusader that I might try 30 minutes a night on to get up to level 70. Just bounties on the highest comfortable difficulty or is there a good farming spot?
This is my gear at the moment:
http://eu.battle.net/d3/en/profile/stokietom-2515/hero/43381366
772k DPS unbuffed, 891k buffed.
I want to replace 'Glamor wound' with 'Unity' (Have 2 of them now!) Just need to get the gems so I can re-roll a stat to crit hit damage.
Any other suggestions guys?
). Hellcat Waistguard (good filler until you get a better one).
For the TF, is this still considered a BIS item, or would a Barb prefer 2 other 1H items. I guess most would play Fire spec so one of the 1h weps would be a burning axe at least.
If not then I could roll the Str to Int and use it on another char![]()
Think Fire Barbs would opt for Sun Keeper + Burning Axe/Devastator. Would just leave it until you need it, might find another later on before you need it for your Barb.
I am so unlucky at this game. I have my magic find at 45% does that make any difference?
.Trying to weigh up Darklight vs Maximus for a Crusader FotH fire build. Was running around with Blessed Shield for a while but FotH w/ Heaven's Tempest does waaaay more damage over time. Darklight seems to hit faster but weaker, gets a 50% chance for a free FotH and will stack more dots from Akarat's with Fire Starter. Maximus has the chain, hits harder but slower, however can use a Hellskull for +10% damage. Also using Provoke for Wrath back, with Maximus I can use another skill like Consecration but with a Darklight I'd imagine I'd have to go back to Shield Glare w/ Zealous Glare to maintain the Wrath costs.
Not sure where to dump all my shards into. 1 handers for Darklight or just keep trying for Akkhan legs then a Cindercoat to replace Akkhan BP. Anyone have any insight?
Priority stuff from me mate:
1. New shoulders should be up your list somewhere. Aim for high Int/Vita/All Res and then either Life %, Skill %, or utility (Cooldown reduction, Resource cost reduction).
2. Helm is okay but obv decent Cold % Andariels, or some leg helm would be good.
I have an Andariels with these stats, not sure what I should re-roll though. Any tips?
3. Amulet is OK until you can find one with Int/CC %/CHD % and Cold %.
Is it worth re-rolling the armor on this to crit%?![]()
4. Bracers are fine. However I would note that if you have the stomach/resources for it, you can craft Reapers Wraps which can roll good stats, and replenish your resource when you pick up health globes.
I crafted some reapers with these stats not sure if they're any good though. I guess I'd need to roll the life regen for crit %?
5. Gloves are OK, but consider gambling for some Trifecta Magefists or Gladiator Gauntlets. Both drop with some frequency in my experience. Magefists can only come with Fire % dmg, but it's a free extra stat so if the rest of the stats are good don't be put off by that fact.
I will start spending some shards then.
6. Belt is not too bad. Ideally in this slot you want one of the following though: Fleeting Strap (you can craft it if you found the recipe). Harrington Waistguard (best belt in the game imo). Witching Hour (good luck finding it). Hellcat Waistguard (good filler until you get a better one).
I have the recipe for fleeting strap, just need to farm the last legendary for it.
7. SOJ is good BUT it's the wrong skill for you, Arcane % isn't helping you out at all and may as well not be there. If you find a ring which has good stats, or a SOJ with Cold % instead of Arcane % then I would use that instead. I would not bother to reroll that ring further right now.
I thought arcane % is helping as I use arcane orb with frozen orb rune?
8. Second ring obviously you mentioned already.
9. Legs are OK, but ideally you want high int/vita/All Res and 2 sockets.
Yeah I'm still waiting for a good leg drop, can't seem to get anything though.
10. Wand is OK, obviously get a 130% crit gem in there instead as soon as you can.
Noted!
11. Your boots are actually pretty nicely rolled. I would focus elsewhere on upgrades.
12. Winter Flurry is fine for Cold spec like yours. I haven't actually found one in my travels so well done for finding one :
13. Consider swapping Astral Presence for Audacity for a DPS boost, you wind up firing at close up stuff quite often so the +15% should be noticeable.
Done.
Do you have any of the set recipes? Cains is popular for the bonuses it gives. Aughilds Head/Shoulders/Bracers are also a popular choice.
I have the full Aughilds set but they're all only level 42 but pretty bad stats, confused with this one.
Finally one thing you could really benefit from, that is not easy to get by any means, is the Ring of Royal Grandeur. This drops from Act 1 bounty caches, so if not solely focused on getting this, I would run Act 1 bounty caches when you can, in groups is best, to give you a shot at getting it.
Noted. This is something I need to get ASAP but I have so many upgrades to go for.
I also got a Shard of Hate last night, was about to log off but did one more rift and got it. I think lightning Barbarians tend to like Odyn Son with a Shard of Hate, but thunderfury also works well.
NP Tom
1. I wouldn't use that Andariels necessarily, you would want that came with Cold % natively, or the rest of the stats were good (Int, Crit %, Arcane Orb % etc).
2. I would not use that Amulet personally, you need 3/4 good rolls to make it worthwhile, that one has only 2 good rolls. You definitely want Crit %, CHD % and Int as a minimum.
3. Those Reapers are no use at all imo. You want ones with the exact same stats as your current bracers really. Cold %, Int, Vita, Crit %. If you accidentally craft the same but with Fire %, Lightning % you could reroll the Element, or keep them as off spec ones
4. The spell may be called Arcane Orb but the rune is Cold dmg (it should show you that on the spell). Therefore only Cold % helps your Arcane Orb Frozen Orb spells. It's still a decent SOJ though but only for Arcane spec, keep it in case you want to try arcane sometime. Keep on using it until you find better anyway as the other stats are still good.
5. You may have the old set, It dropped again for me at 70 so you want to keep an eye out for it. They definitely can roll lvl 70 stats![]()
Ah ok makes sense.
It seems like I've got quite a few useless legendaries then.
Really not sure what I should be doing next....? Do I keep crafting reapers?
What stats should I be looking for on a ring to replace SoJ?
Cheers
