£1000+ Gaming Rig - Spec Check
20 May 2009
Hi All,
I am going to be building a new system for a friend. I tried to Tell him to wait for june for the new cpu refresh. However he really wants to get his gaming rig going now so I have specced out a rig for him.
His max budget is £1200. He will use it purely for gaming, and wants a red and black theme. I think I may have hit this build on its head but if you guys have any more suggestions / thoughts before I pull the trigger your more than welcome to say :)
YOUR BASKET
1 x Powercolor Radeon R9 290X 4096MB GDDR5 PCI-Express Graphics Card £349.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £239.99
1 x Gigabyte Z97X-Gaming 3 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £104.99
1 x EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply £99.95
1 x Corsair Obsidian 450D High Airflow Mid-Tower Case (CC-9011049-WW) £91.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler (CW-9060009-WW) £88.00
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £59.99
1 x Corsair Fan, SP120 PWM High Pressure Fan 4 pin, Dual Pack (CO-9050014-WW) £25.00
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Akasa "Vegas" White LED strip light - 60cm £8.99
1 x BitFenix Alchemy 24Pin ATX Extension 30cm - sleeved black/red/black £7.49
1 x BitFenix Alchemy 6pin PCIe Extension 45cm - sleeved black/red/black £5.99
1 x BitFenix Alchemy 8pin PCIe Extension 45cm - sleeved black/red/black £5.95
1 x BitFenix Alchemy 8Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
Total : £1,185.88 (includes shipping : £8.00).
What do you guys think?
The 290X is not good value and the one you've chosen (OP) has a frankly awful cooler that will almost certainly lead to throttling. Can I ask what resolution / hz he'll be gaming at?
This is a spec, VERY VERY VERY similar to what you specced, that I did yesterday. :)
Does he need a HDD, OD and wireless?
You could probably fit in a 450D if he prefers that case.
The Gaming 5 is well worth the extra few £'s.
WARNING: Ethermaster doesn't stick to budgets very well ;)
Well that's an understatement.
Why is the gaming 5 worth the extra? The gaming 3 comes with a free £32 set of Corsair gaming headset.
The H100i when used with Win8.1 is a bit of a mare. The H105 or the Antec jobbie are easier to set up and work.
He has a keyboard, mouse, spare 1tb hdd and windows 7. That spec is very similar, I gather the gaming 5 doesn't come with the free headset? but if it is worth the extra...
Case wise he left that up to me, after running through many I think he really liked the 450D
**Edit** Haha you guys beat me to it, I will get him to check out the ronin. For it being cheaper that extra could go somewhere else
Darn, missed the free stuff, as a motherboard is it, as a motherboard vs motherboard/headset, it isn't. Well said lads. :)
