Did you actually get 93.361 fps or are you just adding up?
15% higher clock = 15% higher score does not add up to me, clock scaling is never that linear.
Your 81 FPS @ 1175 on your Titan is the same as Tommy on his 290X @ 1175, and yet Avenged7Fold only got 86 @ 1300Mhz also on a 290X and a faster Haswell CPU. while Greg only got 84 on his 1300Mhz Titan.
So 100% clock to score scaling doesn't happen, it never does.
All those add up. Alatar's does not, not even close.
His FPS in all 3 aspects are way higher than anyone, in double digests, it should be marginal if anything.
Its just not making sense to me.
I can't just add anything, if its not right. its not fair on others.
Just add it, not worth the hassle. I want to know what happened to the first screenshot he posted that was 99fps though? Everyone missed that, apart from me.
Scotty seems to think its legit so thats good enough for me.
Seeing as Humbug didn't bother to move my old score over when the thread began as I requested (shocker).
1080P
4960 @ 4.7 (water)
780Ti SC ref (water) 1315/1965
Or was that not legit either?
note this is on an older build of the game. Last time I tried to run it after the big patch, things were in the lower end of the 90s. I suppose I should run it up again to put this to bed. Although if Matt did see a 99fps shot taken down truly, then obviously somethings a little flaky about that![]()
Nice score sir.![]()
Thanks chap. I will do some more testing later once flashed and really go for it. These latest betas would appear to be pretty good for this game.#1, Avenged7Fold: 290X @ 1300/1600, 4770K @4.5 - Mantle FPS: Min 71.4 / Avr 86.3. Link
#3, tommybhoy: 290X @ 1175/1475, 3770K @ 4.5Ghz - Mantle FPS: Min 59.7 / Avr 81.8. Link
#4, Protoo: 290X @ 1208/1498, FX-9370 @ 4.9Ghz - Mantle FPS: Min 63.0 / Avr 80.3 - DirectX FPS: Min 36.0 / Avr 56.0. Link
#5, Kaapstad: 290X @ 1250/1625, 4930k @ 4.8Ghz - Mantle FPS: Min 61.3 / Avr 79.4 - DirectX FPS: Min 61.9 / Avr 80.2. Link
In 6 months time (or whatever), who's gonna care?
I think the AMD crew need to pipe down a bit with the accusations and get their facts straight, speaking forthright. This is an UE3 engine game, everyone knows UE3 prefers Nvidia hardware, before you go anywhere. There are all sorts of factors to consider. CPU/BCLK / RAM speed/ Timings/GPU clocks and drivers on top of that. There is no need for the bitterness.
1080P
4960 @ 4.7 (water)
.Not many people seem to have this game do they?
The ones that do probably got it free with a card or at a very cheap price.
Only 11 entries for a game i thought would be quite popular is quite a surprise to me.
