so it does have a SD card, like the look of this, perfect size for me, all you lot with kids hands...![]()
No word on being waterproof?
I think I'm going to have to physically play on it before I decide now...
Whatever old man - does the massive screen help your deteriorating eyesight?
BTW, do we take removable back to = plastic back cover? If so... eww![]()
People, plastic does NOT equal bad quality. It is how the plastic is used that is key.
My current phone has a kevlar back and is best back I ever felt
RAZR HD? Same here![]()
Urgh!!!
All these rumours and leaks - I'm sooo confused.
As long as the G3 isn't as tall as the M8 or Z2 and has a decent battery to keep up with that QHD screen, a SD card slot (I have a 128Gb micro SD card just waiting to be used)![]()
The lack of 805 SoC doesn't bother me either.
just incase someone shoots it![]()
Larger than some of the leaks had suggested, but still quite an impressive size overall, considering the screen size!
Although I am wondering if it'll be a bit on the large size for comfortable use. I've got fairly small hands (for a guy), but can use my N5 happily with one hand. I'm just a little worried the G3 will be just out of the comfort zone; need to get hands on with one really.
Was really hoping it would come with the 805 though, would make justifying the upgrade from the Nexus 5 that bit easier!
