LG G3 **discussion**
so it does have a SD card, like the look of this, perfect size for me, all you lot with kids hands... :D
Whatever old man - does the massive screen help your deteriorating eyesight? ;)
BTW, do we take removable back to = plastic back cover? If so... eww :(
rumours are a plastic and a metal version.
32GB/3GB RAM
16GB/2GB
Too many damn rumours lol. Only 3.5 days to go :D
People, plastic does NOT equal bad quality. It is how the plastic is used that is key.
I actual like my Nexus 5 over metal phones, its feels nice, its soft, its warm too the touch. Metal at times feels cold and clinical, it is not a very inviting. I have heard the same thing from a lot off friend when they hold my Nexus 5.
Urgh!!!
All these rumours and leaks - I'm sooo confused.
I keep jumping on and off the G3 bandwagon, currently I'm back on. I had a tough time with the HTC M8 and that had a curved back however was too tall for me.
As long as the G3 isn't as tall as the M8 or Z2 and has a decent battery to keep up with that QHD screen, a SD card slot (I have a 128Gb micro SD card just waiting to be used) :p
The lack of 805 SoC doesn't bother me either.
Urgh!!!
Its about the same size as the M8/Z2. - 146.3mm x 74.6mm x 8.9mm -
Larger than expected. :o
Larger than some of the leaks had suggested, but still quite an impressive size overall, considering the screen size!
Although I am wondering if it'll be a bit on the large size for comfortable use. I've got fairly small hands (for a guy), but can use my N5 happily with one hand. I'm just a little worried the G3 will be just out of the comfort zone; need to get hands on with one really.
Was really hoping it would come with the 805 though, would make justifying the upgrade from the Nexus 5 that bit easier!
The many difference for the S805 is GPU, CPU is not a huge step forward from the S801/S800. I think the next big thing will be the S810 which is due 2015.
http://www.anandtech.com/show/8035/qualcomm-snapdragon-805-performance-preview
rest of it can be seen here.
http://www.mainguyen.vn/tren-tay-ch...ung-chinh-hang-danh-cho-lg-g3-sap-ra-mat.html
video of the case
