- 29 Aug 2010
- Cornwall
It's not AMD's job to 'support' Nvidia, Mantle will have a spec and it's up to vendors to use it-or not.
Indeed, but this is going back to the question of if Multi-vendor support is a political issue or a technical issue.
And I think it's fairly likely that Nvidia won't support it, they have no reason to. Intel the same. I've no doubt that there are political reason, just question if the statement that there are no technical reasons is 100% definite.
How Mantle is supposed to become THE graphics API when it seems unlikely that other vendors will adopt it I don't know. If AMD don't want it to be supported by other vendors then why make it open? Just keep it proprietary.
