- 1 Dec 2013
Hi guys which block do u think is the best
under 100 pounds
under 100 pounds
Remember both blocks need to be installed at 90 degrees to get the best performance (one hole above the other not side by side).
I'm on my phone, so I can't link it, but the likes of Bundy and Martin both mention this I think. It's do to with the orientation of flow channels inside the block in relation to the core under the heat spreader. It makes a measureable difference of a couple of degrees if i remember right.Is this empirical or do you have a comparison for this?
Yes.Did it matter what the in/outlet orientation was?
Here you go, it was actually Stren I was thinking of, but others find the same thing:-Can you did out the relevant details later? Thanks.
