- 5 Aug 2006
- Derbyshire
I have a 2007 '57' reg Ghia.
Dad had it since 6 months old and I bought it off him.
It has done just over 90,000 miles and has a 2.0 TDCI engine, which I got remapped.
It takes ages to heat up - So much so that with the facelift they cheated by adding an electric heater in the air vents!
The wheels on the Ghia are prone to 'white worm', which is when water gets under the lacquer on diamond cut wheels and looks like white rust. It is harmless but looks messy. I had my wheels refurbished.
The Ghia wheels are 16", but I like them as the tyre is still sufficiently deep that does not catch kerbs as it is the tyre that hits. This has saved me a few times.
I do not like diesels, nor need one, but the good nick this was in with 95% known history made it a no-brainer. Especially when I bought it for the trade-in value of £4000 in March 2012!
Also watch out for rust where the very bottom of the rear doors meets the rear wheel arch! Stones pummel the paint there. Also check rear arches as mine are starting to go brown - Not happy! Will get a bodyshop on it this summer.
Mine is not a facelift. The facelifts are prettier, but all diesels will be DPF. Pre-facelift does not, but it was an optional extra from the factory (seriously...wtf?!).
Avoid the 1.6 115hp version as it is horrific on fuel. Afaik this was only available pre-facelift and was soon ditched.
The specs of my Focus are:
2007 Ghia
Cruise control
All electric windows
Electric mirrors (not auto folding)
5 door
Nicer Sony stereo that the ST had. No idea on speakers but pretty good imo
Heated windscreen (a must in my opinion!)
Regular A/C
2007 Ghia
Cruise control
5 door
Regular A/C
