system & windows loads fast but software and drivers take longer
29 Dec 2012
system & windows loads fast but software and drivers take longer, it can take a further 10sec to load drivers for usb keyboard and mouse some icons, software like start button.
is this due to graphics card or overclock ?
so? that test the max load of the cpu on how it will deal with tasks.
i had my system primed for 2hr but could not open firefox because it was not stable.
list your OC info here
Best way i have found to test for a stable pc is the use it. play games go on the web. and if it works your ok.
Ive been playing KOAR worked fine, Im going to give rift ago see what happen, what should i expect if its unstable ?
is your system feeling unstable ones it as booted up?
have you tried removing the oc to see if it the same
no ive not tried that,
It boots up fine but some things take a few sec's to load like the usb and start button.
after everything is loaded it fine. ive not see any issues in prime or games.
Your running an ssd it will boot fast. if you have programs installed on one of your mooosive drives it may just be lag.
Save your OC profile then resetting bios. and removing all overlocks then see how it boots
check your ram timings and speed are set right but i think its just lag.
no system is instantly ready
also the base clock on the cpu in your sig is 3.5ghz not 3ghz. reset bios
sorry that what i meant I just pressed the cmos button, everything was default all i had to change was the voltage to offset,
could it be the graphics card i have downgraded to a gtx 280 1gb for a bit till i get a better one.
or is it the start button software im using ?
