MotoG + LTE + SD slot for £149 unlocked....bargaintastic![]()
loving my moto G the battery life is awesome compared to my old phone
Usually loads of juice left even after 2 days
My Moto G has gone back to Motorola, the SIM just wouldn't stay in anymore.
And to put icing on the cake....It toasted itself when I did a factory reset before packing it![]()
Well just went to wake my phone and realised it had turned itself off. Turned it back on and the battery had gone from about 95% to 1%. Luckily I'm near a mains charger.
It's just taken a good few minutes to charge from 1% to 2%. I hope it's ok
edit: and a few minutes later it shows as 100%
Theirs usually a new budget king released every 6-9 months.
I think a new arrival should be on the horizon soon this was released in November 2013, so a new one is due.
<£125 = budget range
£150 - £350 = mid range
>£350 = high end
above refers to launch prices as prices usually do go down with time after initial release
You can usually within the budget range buy and sell phones as soon as the new budget king is launched without any losses on ebay. Staying within the budget range effectively means after your initial purchase all upgrades are essentially free. You usually take about a £5-£20 loss maximum on depreciation due to the fees involved on ebay.
On the mid range phones you usually take a £100-200 loss in depreciation over the same time and £200-£400 on the high end phones after fees.
So even if you buy a moto g today and a new king is launched next month, you won't be losing much if you were to sell it on and buy the new one.
Is the new moto g 4g lte due out this month or next?
Moto G 4g will be my next phone. No longer need a flagship, top of the range phone.
All the press releases said this month, but the preorder on Amazon UK says released 30th June.
Exactly this. Enough with these 500/600 phones. It's just silly.
