**The New Official THIEF-Incorporating Bench mark Thread**
@Kaap,
Someone on oc.net posted a score better than mine and they have the same cpu as you, i think?
A good 14 fps faster than my score at 1440P.
Intel Core i7-4930K Ivy Bridge-E 4.3GHz
290X Crossfire
1440P
Not sure what his gpu clocks were at yet though.
http://www.overclock.net/t/1429303/amd-mantle-discussion-thread/2290#post_22335421
EDIT
His gpu's were at stock.
Have to say (here seems as good as anywhere), while implementing 2-way crossfire (not sure if it goes hgiher) did take them quite a while considering BF4 had Mantle implemented in 2 months with 1 guy sorta working on it, now that it's here they do seem to have done a good job.
Looks like it even works well on 7000 series cards too. I've not compared VRAM usage to DX VRAM usage, but from my benchmark runs it doesn't seem to be an issue.
So credit where it's due.
On a side note has anyone noticed in the benchmark the soldier/guard that looks like he should be holding a rifle or something but is actually carrying nothing?
That and the guy whose feet sink into the floor always mildly amuses me!
Yes, crossfire works well on two gpu's. Very nice. Three and four gpu's needs work, but its still better than DX.
We'll be expecting some benchmark scores from you GM. Failure to comply will result in shortage of cornish pasties being delivered to your quarters.
I've already said I'm not entering more benchmarks (said that in your LuxMark thread I think) and if I did, it wouldn't be this one.
@Kaap,
290X Crossfire
1440P
EDIT
He is not using max settings that is for sure, look at his min and max that does not look right for Mantle.
Here is my 2 card Mantle score so you can see what I mean.
Two card 1600p entry
2 x 290Xs @1230/1625
4930k @4.8
Then it is a pretty awful score.:D
What do you get with three cards at 1600P? He said scaling on the third card was meh. He's running a low cpu clock though which probably doesn't help., 4.3ghz. I have not forgotten about our comparison either and will do that at some point.
I will look into it and post in a bit.:D
Yes and fixed
How do your DX titans compare to your Mantle 290's Kaap in Thief in terms of fps averages? Has Mantle tilted the performance of Unreal Engine (always a Nvidia favourite) back towards AMD? There's a shortage of Nvidia dual/tri gpu runs to compare to. The only one i could find were Scottys and Gregs runs from the old thread.
1,2,3,4 GPU's @ 1080P, 1440P, 1600, 4K...... jeez ##### hell Kaap, winding me up with all these different configurations, why can't you just have one normal Gaming PC like normal people :p:p:p:p:p:p
Done. :)
