Hitting a child should be a jail sentence.
I'm embarrassed you support the same political party as me
Were you hit as a child?.I'm embarrassed you support the same political party as me
Using violence as a method of control simply teaches a child that it's acceptable to use violence as a tool to get your own way.
If it's okay to give a child a bit of a smack if they are naughty, can I do the same to my girlfriend?
Correct me if I'm wrong here, but the term violent simply has to fit the criteria of the standard definition.
"Using or involving physical force intended to hurt, damage, or kill someone or something." - " Behaviour involving physical force intended to hurt, damage, or kill someone or something:"
Assuming the child intention is to hurt then does it not fit the above definitions?, from what I recall the term admonishing isn't synonymous to any other terms which imply the physical - just psychological or verbal.
No.
I've NEVER smacked our two, and they are very well behaved.
That's not really the point is it, in later life physical punitive measures are illegal & will land you in trouble with the law.So would you say that any form of corrective discipline teaches a child that it's acceptable to use punitive measures to get their own way?
That seems to be making a big assumption (on the intent of the child) & missing the point.But the point is that the child's intention is not to hurt - it is to admonish. Without intent, it is not violence. Admonishment isn't specifically about physical or psychological.
my main concern is the average person being the insufferable moron they are is likely to consider the situation extreme when in reality it's the end result of more bad parenting.
My order of discipline:
Tell not to do something
Explain why I don't want them to do something
Warn that if they continue to do it, there will be consequences
Threaten consequences that can be followed though on (take away TV time, slap on the legs etc. Using something you can't follow through with - such as not going to disneyland this year - is counter productive)
Follow through with consequences
I do use a light slap on the bottom or legs as a last resort. Not enough to leave a mark or actually hurt but enough to shock. I've only had to do this twice in 10 years though. Normally raising my voice is enough.
The relationships connecting the use of physical punishment & later life violence are already well established.
yes and yes
In the con argument - when you see children whose reaction to a falling out with another child is to hit that other child: where do you think they're learning that from, and do you think it's acceptable behaviour?
