***The Vapers Lounge***
Status
Not open for further replies.
Thanks Tommy. I will get the cheap charger but if I like the clone I will get the i2 you suggested.
I just trying to get everything off one site and that site has the magnets for the clone as well.
Thanks again.
Of all the things to save £6 on, don't skimp on a charger!
The Nitecore i2 you can get for £13 with free postage.
Oh balls :( dropped my hana in the bath last night :( so freaking stupid, ive never ran around the house so quick looking for a screwdriver in my life, surprisingly there wasnt any water in the battery housing, but a bit of water under the perspex, so i had to dismantle that part to get it clear - almost managed to get it off in one piece, but it snapped, they use a lot of hot glue in there and i mean a lot, im surprised water got in at all, sat in a bowl of rice over night, and now on the window sill to make sure its dried out fully.
Ordered some more perspex to make a new cover for the electronics and a replacement efest 35amp incase this one is no good now.
Never dropped any of my mechs before, im blaming the alu body of the hana lol
Well to update, it lives! thank god, its totally dried out, with a bit of misting to the screen which im sure will go with time, the efest battery actually is perfect, charged to 4.2v no issues, holds it fine and discharging at a normal rate - just waiting for new perspex to replace the broken bits and it will be all good.
+1 Myepack, but spend the extra fiver and grab the i4 v2.
+2 for myepack!
Ordered myself a handbuilt 8.5bore Spartan Chalice bronze drip tip yesterday to go with my kafun & copper v1. Have some Minion Fart and Swedish Fish being delivered today from kraken. Lovely
I saw you mention Minion Farts the other day Josh, go me some of that too, (Vaping Kings Monkey Jizz is one of my faves), along with Kingslayer and Crystal Menth. Gonna give them a week or so to steep though. :)
I tried the monkey jizz fron kings, really didn't like it, the after taste wasn't right for me.
Yes I have heard you can steep the minion but I'm out of juice now so need to use it, think I will let it steep whilst I'm using it.
Going to make my first coil with .28g wire this evening, hoping to avoid the dry hits I keep getting from my current build.
I want to try the gingerbread one on kraken so just about to order some more lol - fatal.
Anyone have experience with the Vision Spinners or eGo Twists? Want a step up from my basic plug in and go batteries. I do currently have a mini protank 2.
Does changing the voltage settings on these pre-determined spinners make that much difference?
Thanks.
I had a couple of twists but sacked them off for a vamo v5 quite quickly. Then mechanical mods soon after that but I still use the vamo when building coils to check resistances etc.
Thanks all above. I might look into a Vamo V5, is that much bigger than a normal ego battery? Ideally I want to keep the size similar, and I take it I can just put my mini protank straight onto that?
Well I got my i4 V2 charger from the forest for under £16 with delivery. Got my batteries, so I'm good to go :)
Sending a mate off to B&Q to see if they sell the magnets for the switch in the nemesis.
Thanks all for helping again.
So wish that I'd done this instead of getting an i2, if I've 4/5 batteries to charge it's an absolute chore! :p
On a hunt for a copper mod and RDA......a bit of research tells me that there is less voltage drop on them, thus maximizing any potential cloud chasing :p
vamo is fatter, like 21/22mm I think. I only ever use the smaller 18350 batteries which keep the length down. you can see it here with both size batteries in it.
http://img.photobucket.com/albums/v497/limbot/vamocomparo.png
you can use any ego or 510 threaded atomizer on it... so almost every one on the market these days.
Status
