Peugeot Bipper Citreon nemo
17 Jun 2007
Hello Motors
Anyone drive a bipper or Nemo. Were looking at buying 6-8 new vans and have been offered a decent deal on bippers.
Currently running Fiesta 1.4 Tdci's which are lasting 200-250k miles before dying.
Trying to work out whether saving a couple of grand now will bite us later if the bippers only last 150k.
22 Oct 2007
Hull
We use Bippers in our fleet and they are poo, the most common thing being the dpf filter which puts it into limp mode and needs cleaning out. So if you only travel short distances then you will be in a continous cycle of getting the dpf cleared. If they are going to get a regular run down the motorway then the issue wont be as bad.
OP
17 Jun 2007
Between 300-400 miles per night so should be ok.
A little worried about saving a couple of grand now over buying fiesta's and then the bippers failing 75k miles short of what we get out of the fiesta's
22 Oct 2007
Hull
well personally if you can stretch to the Fiesta then I am sure they will serve you better than the Bippa, they are ok to drive on a plus point buy not for long distances and they feel about as cheap as you could imagine.
EDIT - Not sure if this will help but we use transit connects too and they are much more reliable.
OP
17 Jun 2007
£2-3 grand extra over 8 vans is almost a 9th and 10th for free.
I'm sure the drivers would prefer Fiesta's as they drive more like a car
5 Sep 2011
East Sussex
i drive a citreon Nemo, do maybe about 300 miles over a weekend, and nearer 1k miles during the week, its not the most exciting thing to drive, steering is very light, my van is a 2010 plate and just gone over 70k and nothing really has gone wrong apart from replacing disc's and pads about 20k ago, but that was because some other numpty driver thought driving through a deep puddle in a gravel car park was clever and stones got them selfs inbedded in the discs.
I have absolutely no problem with the van it does what it needs to fine, but if i had to choose a van myself, i would probably go with ford
13 Dec 2004
Stoke-on-Trent
We have a Nemo at work. For the love of god do not get the semi auto. Quite possibility the worse gearbox I've ever used.
Also, the wing mirror glass vibrates loads over 60mph. Strange, probably something wrong with it! Other than that not had a nig go wrong in 30k miles.
OP
17 Jun 2007
Wont have any fancy bits on it. We install Parrots and thats about it.
21 Oct 2002
We run a couple of kangos (I know not the same model or make) in the fleet.
The are horrible compared to the Mercedes and fords.
Everything the French make just feels so horrible and flimsy.
22 Dec 2018
Any chance you could shed some more info on the dpf on the bipper having the same issue with mine even after a manifold clean
20 Oct 2005
If you do 1k a week how does your 2010 van only have 70k on it
