Can a few of guys look within the postcode g742aw, maybe within 100 miles and see if there are any good deals, max spend is £7000, either a coupe or a saloon.
Any colour apart from gold
Thanks
Ps bot my real postcode but close enough...
The only one I can find that looks like it might be remotely interesting, facelift and reasonably close is the following:
http://www.ebay.co.uk/itm/BMW-325ci...tomobiles_UK&hash=item1c41446f50#ht_884wt_958
To be honest, I think it's very strongly priced (probably down to the mileage) as no matter which way you paint it, the 325 is less desirable than the 330 and automatic cars are not remotely difficult to find which again makes it that bit less unique. Gut feel £4k would be more reasonable, but given that you're down into the hundreds of pounds difference bracket it's possibly just worth paying a bit more for the right car.
It's worth looking at both the 325 and 330 as a good 325 will feel no different power wise (maybe better) to a 330 with some issues.
You'd need to ask the right questions beforehand and really go have a look at it, preston's a short (and usually cheap) train journey from Glasgow if you decided to go see it.
I'd want to see the history to make sure it's actually been serviced properly, not just taken to BMW until 3 years old then given an oil change every year by some backstreet mob. Thorough check for rust and detail on all work carried out since the car was about 5 years old
