Google Maps Navigation not choosing quickest route?
18 Oct 2002
UK
I'll be driving along with Nottingham>Bedford as my journey. I'm 20% through the journey and it says 1:10 as my ETA then at the next glance down it'll say 1:18 as the ETA, but it hasn't prompted me to do anything, and the bar is still showing as green (no traffic) and when I drive past the motorway exit I would have taken it has this little grey box I can see that says '8 Mins faster'
Usually these come up as 'slower' but super genuinely I have seen a few come up as faster recently? What is up with that?
It's caught me out a few times now. Only happened in the last month. I'm pretty sure I've reset the cache of the app in that time but I'll try it again.
I've had this on several occassions.
Set my route to get me from Bedford to the A1 to follow it north. As I was approaching the A1 it told me to turn around and go up the M1 adding significant time. I ignored this and re-routed it again - no traffic issues on the nav.
Another time I was heading up the A1 toward Lincoln. It told me to go off the A1 and follow some random A road to Lincoln adding 40 mins to the journey. Ignored and it went back to normal...
I have been having these issues too.
I would manually select the fastest route then whilst driving it selects a longer route even though the current route is fine.
I also noticed whilst driving it sends me on my current route and another street had 5 mins faster on it and I should have turned off.
So it automatically re-directs when it shouldn't and doesn't when it should.
It's borked atm.
Is that only recently Amos?
Like the last month or so, probably the same time they added the eta function I think.
Yep. Only the last few weeks. Also noticed some force closes of map app after a few hours of navigation. That might be my rom though but no other app issues.
It's borked atm.
It did work well the other day. Popped up saying an alternative router is quicker - it bypassed a big queue of on the M6 with me only needing to press 'accept new route'.
Looks like this issue needs a bit more googling when I'm home then.
I've had would you like to accept new route pop up too, shouldn't be that automatic anyway, this borked issue aside.
Yeah I've had this issues several times over the last few weeks... best was when it offered me a route "18 minutes faster", so I thought, yeah I'll have a bit of that.
It took me off the highway on an exit, went round in circles on some country roads, then brought me back onto the same highway at the next exit.
Fail :p
I've similar problems. It tried to direct me off the A1 about 2 junctions before the Peterborough exit which would have taken me around a shed load of B roads.
I just ignored it and let it re-route which also took 16 mins off the arrival time.
Fail :p
Yep, had that happen too.
I use Here Drive on my Nokia phone now for satnav duties, much better. And as it happens, bigger screen too which helps.
I have had Google Navigation just stop on me several times during the same trip on the same night. Once heading to Stanstead airport and the other coming back. Stupid thing didn't appear to crash just stopped and screen went into power saving/stanby. Google Maps hadn't crashed so I managed to get things back up and running again.
I've had it crash a few times, which I don't mind as at least I can reset the thing. But to appear to be working fine but at the same time sending me all over the country? Bonkers!
You need to use is as a guide. Sat navs have never been 100%
Understood of course, but before this Google Maps has genuinely been 99% great, never rerouting in stupid ways or sending me up the side of a mountain/off a cliff as per the normal satnav horror stories.
Using and comparing different Nnavigation apps has beccome almost a hobby for me so I've had a lot of time to reflect on what's available. I've used pretty much every navigation app under the sun - at least on Android.
Assuming map data is up to date (no new bits of road, long term closed roads etc), Tomtom destroys Google for sensible rerouting around traffic - and accuracy of traffic info. The main difference, I think, is Tomtom's historic speed profile data that acts in conjunction with the live traffic. It has data for average speed for time of day and day of the week for every road (not just the main ones). The live traffic can also theoretically detect traffic on any road. I have seen it work occasionally even on side streets. This means that with Tomtom, diverting off a main road is not just a voyage into the unknown. If Google sends you on side streets or rural white roads, it may well be out of the frying pan into the fire (pretty much the same on the majority of other apps that offer traffic rediversion). Tomtom's traffic is not correct 100% but I'd say it's right more often than not. I've grown to trust it - I used Tomtom's own app for a year before switching to Route 66 and have seen it improve significantly as it's been upgraded.
The cheapest way to get Tomtom traffic in a navigation product is Route 66 Navigate on Android or iPhone. It has a 30 day trial, including Tomtom HD traffic. I've been using it about 7 months. In short - it's brilliant. It uses a slightly different routing algorithm from Tomtom but the same data. I keep checking Google maps to see if updates have changed it much but it's usually nowhere near as good as Tomtom for any routes that send you off the beaten track.
Both Route 66 and Tomtom can be set to either automatically reroute if faster routes are detected or to ask the user. I prefer the entirely automated option for entirely hands free operation.
The disadvantage of Route 66 and Tomtom is they're never close to Google for keeping maps up to date. Updates are quarterly on Tomtom and less often on Route 66. They both allow you to block part of the route to mitigate this though. Also, the search and POI info in Tomtom and Route 66 is nowhere near as google maps. There are occasions when I'll find the location in Google Maps and then use Route 66 to Navigate.
Tomtom's own app is also better than Google for traffic avoidance but it's more expensive than Navigate and pretty clunky (especially the Android version).
The fact that google maps/nav is free and other apps very expensive. I don't see the need to pay for a sat nav. Google maps for me has always been perfect, only recently has it had issues with this faster route stuff.
Cost wise, it depends doesn't it? I changed to 3's 3-2-1 PAYG tarriff during the winter so now, apart from a small allowance (150MB per £5 spend), I pay by the megabyte (1p). Therefore onboard maps are beneficial (cacheing aside). I've not sat down and worked it out, but I suspect that Route 66 Navigate now works out cheaper for me than Google Navigation.
Horses for courses eh? By comparison Tomtom uses about 10MB and Navigate uses about 30MB per month (all live traffic I guess). I do any major downloads over wi-fi. Anyone use Google maps for a daily commute and want to comment on how much data it uses per month?
I'll be honest I usually connect turn my sat nav on before i leave the house and type the destination in, etc so it starts routing whilst i'm still at home just about to leave.
I then turn the screen off (to save battery life) and then leave and get into the car, where the screen is then turned on and placed into my phone holder.
therefore i use hardly any data compared to doing it out on the road.
obviously though on the return journey i use data to load the maps and it' uses data for constant updates.
i only have 1GB but you can get unlimited data on giffgaff for £12 a month (£2 more).
do you have a link to the 2 android apps your recommending?
i have about £30 worth of credit for amazon apps but they only have one nav app on it and it's meant to be crap.
