Any ideas what I can do about these lights?
10 Jul 2006
First off, I rent so can't make any major changes.
I have some directional lights in my living room. The problem is that any angle the lights are at, they get in the way (ie shine in my eyes when I am sitting down or watching TV.
My solution at the moment is to only have two on, but that means the room is not very bright. and even still, there is one of those that gets in the way. There is nowhere that I can point them that they won't get in the way.
Here is a picture: https://drive.google.com/file/d/0B4Mz-WnXHUIIbHhpUDRhdkhnbDQ/edit?usp=sharing
Any ideas?
Can't really see in the picture at that zoom, but what bulbs are they? Something like a GU10? You can get them in loads of different beam angles. So a bulb with a 120° angle would be a lot wider spread and less intense than a bulb with a 40° angle.
Alternatively take them down and replace them then just put them back before you move out.
as in the design trade you can always spray the bulbs with High Temperature Spray Paint vitcas range ,works well with the correct colour :D
