Yeh I know, I can charge at work, and I think any e bike should* be able yo do at least 30 miles, no?
So would you recommend me buy a normal hybrid bike no motor, at 13kg would that be the better option?
So you wouldn't recommend the stealth for a 13mile commute one way?
I was thinking to just go ahead and order the woosh big bear since it boasts 40miles plus. but I thought maybe cyclotricity since you keep saying good things about them.
ask yourself, can you ride normal bike 36 miles to work daily? if no. then ebike wont fix the problem.
having a ebike doesnt means you can travel further. it makes the bike easier to......ride. thats the whole point of the ebike.
so you can use shared cycle paths that are on paths? bus lanes that are for buses and cyclists only?Anywhere you can legally go on a bicycle you get go on a motorbike.
i really dont know what is your problem mate? it seems you have a personal issue with another people having their own opinions.
Have u read the docklandsboy review of the cyclotricity stealth? He claims 37miles on throttle alone?
What you have said makes no sense, that is not a personal issue lol.
Let's do a little maths here.
If you can cycle for 30mins on a normal bike at 10mph that's 5mi, if you now get an electric bike and cycle at 30mins at the same effort, now doing 20mph, the electric bike is allowing you to go twice as far for the same effort over the same amount of time. Do you understand now? It's not a matter of opinion, it's maths/physics.
Ur right the ebikes are like 10kg heavier
