Melting Steering Wheel
3 Jun 2012
hey
As we all know some steering wheels can suffer from a sort of melting caused by heat.
This is evident in the Clio Mk2 Cars.
I bought a second hand wheel that had both thumb grips in great condition but the leather has suffered some melt in places, Which i don't like.
I'm looking into a way to remove this melt and bring back a nice smooth finish to the leather on the cheap (<£20).
Does anyone have any idea on how to remove the melting effect and finish the leather off nice? Its off the car so i can take my time on it if need be.
My Plan is to make it look and feel nice and then do the same to my original wheel and replace its thumb grips.
Thanks All
I didn't think there was really much you can do when the leather is damaged like that. If leather is a bit dry or cracked sure you can use balms and stain it back to colour but i'm not sure what you could do when it does that weird melty thing apart from getting it re-trimmed.
Well I can infact "shave" the melt off but it then leaves lines on the leather. I'm sure there must be a way to smooth it all out
You'd be best off sending it away to get retrimmed by someone who knows what they're doing tbh.
Had various quotes for that, all over £100.
And tbh its a spare wheel so i don't mind trying myself and if it screws up i will just use Snappy from CS to do it.
I think i may end up Buying some of that leather trim from Ebay and stitching it on myself, I will report back when i start with an update and also the final look.
