The 95w phenom ii parts had a 71c max temp on the amd site.
Great results Humbug! The FX-8350 is an awesome CPU.
I'm not 100% sure about the max temps, but iirc it's 85C...I'll check with my team and get back to you.
You normally don't want to go past 1.5v and usually temps will stop you first beyond that. I think AMD quoted 1.6v to 1.65v, though that scares the pants of me!!
Great work with the benchmarks, very thorough.
Great work humbug. Much appreciated.
Don't pay too much attention to p95 for stability with fx8,fx6 etc, (even though I have in my sig)
It just presents an unrealistic core load and temp load which doesn't represent the true stability of the system. You seem to be hitting the higher v-core a little bit too early for 4.6ghz but maybe theres some scope there for more, although temps are probably causing the higher v-core for stability, also adjusting the ht-ref and finding a sweet spot supposedly reduces the temps a little too.
i think they may even push the gaming performance up another 5 to 10% vs the 1600Mhz RAM i'm running now.I think I was around 1.4v to get 4.5Ghz close to stable. I don't tend to get good clockers
Still I was playing a lot of Guild Wars 2 at the time and both chips (Phenom II X6 and FX-8350) were complete pants for that game. I think the FX-8350 was worse than the PII X6. I think I was running a 7950 in the PC with it and my FPS was usually under 40fps on highest setting at 1080p. Dropped a 4670K (and later a 4770K) and motherboard in instead and fps was usually around 60fps (which is what I limited it too to keep the HIS 7950 IceQ Boost quiet-ish).
its not stable in P-95, but i agree with what your saying, Hand Break is the most stressful 'real' application i use, if its stable in that then its stable, i don't see the point in trying to get it stable for 24/7 use in an application which pushes the CPU way beyond anything normal, besides that i have had CPU's stable in P-95 only for it to then fail in real apps.
I may try for 4.8Ghz later on, but on my £30 cooler i doubt that going to be viable for 24/7 use
i will be getting 2400Mhz RAM soon. its capable of running them so i can't noti think they may even push the gaming performance up another 5 to 10% vs the 1600Mhz RAM i'm running now.
And later possibly water cooling
I wasn't aware anyone was concerned about putting 1.5v into a phenom? I always obeyed a 1.55v max rule, I thought most people did.
