What have you done to your car today?
Car started making that horriffic metal on metal screeching/scraping sound again when I went to drive it home just now. It is intermittent and whenever I need to show someone (my mechanic for example) it doesn't do it.
This time I pulled over, took the front nearside wheel off and recorded myself turning the hub, which causes it to make the noise. Poked around in there for ages trying to see something catching on something but could see nothing off... Perhaps something has just dried out and needs greasing.
Just when I thought everything was sorted with this damn car. It is probably playing up because it knows my plans to sell it.
Either take the disc off or get a big old screwdriver and bend back the guard a bit - probably something caught in there
Being out depositing sweat on the lanes of North Wales meant the best I managed to do with my car today was tut tut at the amount of dirt and sand that yesterdays thundery rain has splashed all up the side of it, over the bottom of the sills and all over the front bumper too :(
Fitting an EGR blanking plate. Car runs much better with it, even though I had hardly any smoke to being with.
Broke it!
Crank pulley decided to divorce itself from the car, like the bitch it was it also took a few other things with it!
Purchased new rear shock absorbers for it along with some new top mounts.
With the exception of ARB bushes, my suspension overhaul is now complete :)
I swore at mine a lot today.
It seems my speedo and rev counter have decided to stop working if the temperature gets over 21 degrees!!
Stupid piece of crap must have got wind that I'm going to sell it so has decided to start rebelling and costing me money. :(
I crashed my work van today... Into a cage that did a tiny dent but completely killed the locking mechanism which caused chaos and put me 2.5 hours behind.
O the drama...
Had a trip over to Dynodaze tonight :)
197bhp @ 4641rpm
239ft-lbs @ 4098rpm
Not too bad, pleased with the result. Time for more power though!
Same thing happened to me in our Falcon a couple of years ago - harmonic balancers are a disaster when they go!
Its a crazy design (admittedly very clever!), rubber is always going to perish so why put it somewhere that could potential do a lot of damage, that bit of pulley weighs about a 1-2kg, not something you want loose in the vicinity of the cam belt!
ARGH I HATE CARS.
Took the bonnet off the Westfield. Removed a sensor. Went to put the blanking bolt in instead.... ARGH CAN'T FIND THE BOLT. Search through the jamjars of assorted bolts and can't find one that fits. Swear a bit. Measure the bolt thread size so I know what bolt to buy in town tomorrow. Go to put the bonnet back on, and the damn thing won't fit on. Not even attempting to lock it, just can't put the bonnet on.
RAAAAGE. Don't you just hate it when it's 8PM and that quick 15min job isn't even finished yet.
Sweet :) Any map tweakage to push the power higher up the revs or does it stay pretty level anyways?
That's down to the crappy standard T25 turbo, hits about 1.3 bar but after 4.5k the turbo can't flow enough and drops to about 0.6bar at 7k on the limiter!
The actuator is about knackered too so that doesn't help.
GT28RS in a couple of months time :)
Had new suspension fitted. After upgrading from a Mk3 Mondeo in December I thought the RS handled quite well for a big old barge but nowhere near as well as my R34 did and at low speeds (<20mph) the rear felt very loose, especially on right turns if there was a bump mid-turn. Plus the rear made alsorts of noises over bumps. Soon afterwards both MRC and Unit20 unsurprisingly told me the DRC suspension was shot.
Jump forward to today and I've just had a set of Bilsteins and uprated ARB's fitted and the difference is phenominal. On the way back from MRC via a bunch of back roads the confidence I had from the new setup was great and I regularly hit corners 30+mph faster than before (I know the roads very well!) .
The car now handles how it should have done from the start although I'd love to have a drive of a car with fully working DRC just to compare. It's currently set at as close to stock height as possible with the dampers set to 4 which gives a better ride than the knackered DRC did and doesn't feel crashy on Oxfords very pot-holed roads.
This was the 3rd set of DRC to fail on my car in the 80,000 miles since new and each set is upto £2000 to sort hence the replacement with aftermarket.
So overall a working set of suspension is awesome!!
