**CRYORIG is new and so is R1 cooler!**
they seem to be hot on design but not so much on sales/distribution - they really need to get the things into OcUK, Caseking, Newegg etc.
All you need is a d14/d15 in there as well and that would be a great review/comparison and help a lot of people make there decisions
Okay, here is NH-D15 and PH-TC14PE
Better than all, including CLCs that are 6 to 7 times as loud. :eek:
Make the CLCs stay below 40dBA and air wipes the floor with 6-9c better coolng. :D
System Specifications
Processor: Intel Core i7 4770K, 3.5GHz Stock and 4.4GHz OC
Motherboard: MSI Z97 MPower Max AC
Video Card: EVGA GTX 770 Classified
Memory: 8GB ADATA XPG Xtreme DDR3-2133
Case: NZXT Phantom 530
Power Supply: be quiet! Dark Power Pro 10 850W
Hard Drive: Patriot Pyro SE 120GB/Western Digital Caviar Black 750GB
Media: LG BD-R
Operating System: Windows 8.1.1 Pro 64-bit
Thermal Paste: Noctua NT-H1
Review by George Cella on HiTech Legion
http://hitechlegion.com/reviews/coo...1-ultimate-cpu-cooler-review?showall=&start=2
That graph is not accurate.
The temperature for the h100 is too high.
my i7 4770k is @1.3v using ibt on high it doesnt go above 62-65.
EDIT: Also 4.4ghz
I think they are accurate. We are talking 6c difference with fans at full speed... and that can easily be explained away:
  • A couple of degrees for accuracy.
  • CPU chip silicone lottery degree differences.
  • Couple degrees for different room temperature.
  • Couple degrees in mass produced cooler quality.
Chip lottery will play a very signifigant part, for example my 4770k will go straight into the 90's under p95 on 1.2800v at load for 4.5ghz. Cooler is an alpenfohn k2 with x2 corsair sp PWM fans at 2350 rpm. IBT is a definite no go for me.
The AIO units can all be beaten by high end air coolers.
If you want water cooling do it properly not poor mans nonsense that end up leaking.
CLCs sell just like mountain / trail bikes with knobby tires in city bike shops sell to people who ride on tarmac. Lots of hype and no common sense.
Yea 1st time there but they come from Germany (not sure what support will be like).
And you says it will still block my Top PCI-E slot as its not offset high enough?
What about Ram slots?
Trying to scale off of Asus webiste image I come up with 72-75mm from center of CPU to edge of PCI-E slot. Cryorig is 140mm wide so 70mm from center of CPU to edge of cooler.
RAM slots are never a problem, but RAM that is too tall is. :D
Cryorig says RAM up to 35mm tall will fit. But that would mean case would need 178mm CPU clearance.
Here is a drawing of R1 Ultimate with all measurement I could think of
Nice looking cooler but who wants 1281g = **2lb 13.186oz** thats roughly a bag of sugar hanging from your motherbroad.
If it was me l would use something to support the cooler and to relieve the weight of the mobo.
Make sure you put all the mobo screws in especially in the top half or your mobo will wrap.
Thats one of the reasons l went custom loop was the size + weight coolers were getting to cool the CPU.
That old myth should be buried by now.
A cooler being heavy does not matter as it has a backplate on it, unless you plan to drop the Mobo from a height onto its edge I see no issue.
Once fitted its the strongest part of Mobo and what use to lift it in and out of case.
