Mounting rads together
Caporegime
9 May 2004
Leafy outskirts of London
Any reason why this wouldn't work (apart from being more flow restrictive compared to a 480 rad)?
There are a number of air coolers now with fan>fins>fan>fins set ups, I was wondering if the same could work for rads.
So you would have 2 120mm fans connected on both side to 2 240 rads. with another to fans either blowing in or sucking out on the other sides. (or three sets of fans if you want insane airflow)
90º fitting for the first rad entry, short tube between the exit and entry of the 2 rads, and another 90º for the exit of the second rad.
This means you can have an almost cuboid rad set up, rather than the normal rectangle or square set ups.
Cheers, looks awesome, but I would have thought that many would add significant restriction over 2x 240 strapped together!
Subbed!
