18 Jun 2014 at 10:11 #1 sylarzero sylarzero Associate Joined 7 May 2014 Posts 10 Hi, i have a couple of R9 280X's GPU's will they work ok with intel i5-4670K or is it recommended to go AMD for the CPU for best performance. Thanks
18 Jun 2014 at 10:20 #2 David Bisset David Bisset Associate Joined 31 Oct 2012 Posts 2,243 Location Edinburgh 4670k will be grand
18 Jun 2014 at 10:21 #3 Doomedspeed Doomedspeed Soldato Joined 13 Oct 2011 Posts 11,881 Location Melbourne, Australia Hi, When you say 'couple' do you mean your are running 2 x 280X's in Xfire? The 4670k or 4690k is the best option. AMD CPU's can but aren't great in Multi-GPU setups.
18 Jun 2014 at 10:22 #4 RJC RJC Don Joined 29 May 2005 Posts 29,079 Location Kent You should be fine with the 4670k, don't forget to overclock
18 Jun 2014 at 10:24 #5 sylarzero sylarzero Associate OP Joined 7 May 2014 Posts 10 Thanks guys !! i thought the Intel was the best option, but a friend told me AMD would be better :s and yes Xfire
18 Jun 2014 at 10:29 #6 Doomedspeed Doomedspeed Soldato Joined 13 Oct 2011 Posts 11,881 Location Melbourne, Australia sylarzero said: but a friend told me AMD would be better :s Click to expand... CUZ IT HAZ 8 COREZ THO, MUZT B BETTA! Intel has a stronger architecture currently, so it handles Xfire/SLI better.
18 Jun 2014 at 19:43 #7 Annihilation Annihilation Associate Joined 10 Jan 2004 Posts 155 Intel all the way. One thing I think AMD does better are the iGPU s no good for you.
18 Jun 2014 at 19:44 #8 Doomedspeed Doomedspeed Soldato Joined 13 Oct 2011 Posts 11,881 Location Melbourne, Australia Annihilation said: Intel all the way. One thing I think AMD does better are the iGPU s no good for you. Click to expand... Not on the FX series, those chips have NO (zero) iGPU, the APU's do, they are very good for HTPC's and the like.
