I've had it for about an month, and it's installed in my computer, is it possible to SLI an different model like the Titan and would they work and be compatable together ?
I suppose I might put the money on standby for something else then like an 4k lg tv![]()
thats really a bad idea xD
1-TVs often have higher latency = bad for gaming
2-Tvs most often have refresh rate of 30hz = all games run at 30fps that sux
3-i dont know of 4K movies, or tv channels, everything is 1080p, so if you are not buying it for games(which it isnt great) buying it for movies and stuff, would be a wast of money, because there is practicaly no 4k content other than gaming.
as said above use the money to upgrade Mobo and CPU, also add some Ram 16Go would do it, and if you still planing on sli/3way you might consider getting a 1200watt PSU.
