The new error code indicates:
0x1E = increase vcore (cpu)
You will need to set the voltages manually as it seems like auto isn't doing it correctly.
New card stresses the cpu more hence why old card wasn't giving a bsod issue.
This.
14.4 WHQL are the only drivers that don't give me BSOD with my 290. It would happen 90% of the time when viewing a youtube video.
This time with the error 0x0000000001ELike I said before you need to set the right cpu vcore voltage. Change from auto to manual and put the right voltage. the is the same error code indicating unstable vcore.
This is the tool to use for uninstalling driivers:
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
The procedure would be to first use the amd drivers uninstall manager to remove as normal and then run the tool to get rid of the left over files.
After a system restart install new drivers.
No idea why your're getting the warning, what is your system spec?
Here is a thread i made not to long ago where i had a problem when i upgraded to a 290x and it was my vcore that needed increasing.
http://forums.overclockers.co.uk/showthread.php?t=18603064&highlight=startername_erazor51
I can't believe it was just some drivers causing such a big problem. I have been able to clock up my cpu to 4.3Ghz and ram to 1866Mhz (cas9). It's time to play with the graphics card now. Any suggestions which software is best to test the gpu for stability after overclocking it?
I decided not to mess with the core voltage. I increased the power limit to +50 and have managed to achieve an overclock of 1105Mhz core and 1450Mhz memory clock. I might still be able to push these further without having to mess with voltages but I think I'll probably just leave it here as I don't wanna push the gpu unnecessarily. The max temperatures I saw during the game was 65C with 65% fan speed.
