The new error code indicates:
0x1E = increase vcore (cpu)
You will need to set the voltages manually as it seems like auto isn't doing it correctly.
New card stresses the cpu more hence why old card wasn't giving a bsod issue.
This.
14.4 WHQL are the only drivers that don't give me BSOD with my 290. It would happen 90% of the time when viewing a youtube video.
Like I said before you need to set the right cpu vcore voltage. Change from auto to manual and put the right voltage. the is the same error code indicating unstable vcore.
This is the tool to use for uninstalling driivers:
http://www.guru3d.com/files_details/display_driver_uninstaller_download.html
The procedure would be to first use the amd drivers uninstall manager to remove as normal and then run the tool to get rid of the left over files.
After a system restart install new drivers.
No idea why your're getting the warning, what is your system spec?
Here is a thread i made not to long ago where i had a problem when i upgraded to a 290x and it was my vcore that needed increasing.
http://forums.overclockers.co.uk/showthread.php?t=18603064&highlight=startername_erazor51
