are you still getting any crashes? and was that with 14.6 it was crashing?
OK i set everything up like you said, one thing is there was no crossfire option in CCC.
http://imgur.com/oImfw6e
Ended up with this after heaven, i watched the overlay and both gpu's usage was going between 85-100% with temps reaching 64ish degrees on both chips and afterburner shows the same, also the crossfire image in the top right was there.
http://imgur.com/eUAOdSD,MHcJbIk,b9ue2l4,TdkwBCv
low temps here because i had just started running it.
Ok ive formatted the pc and installed all drivers with no issue. I ran heaven at max and was getting around 80-120fps and 66 degrees, so pretty similar to before. This still seems kinda low![]()
That looks ok to me. One thing you can do it set power limit to +50%. Play some games and see how they perform and let us know.
Shouldn't a 295x2 be performing a lot better than that, especially only at 1080p?
remember your cpu is at stock so it'll hold it back.
at 1080p your cpu is bottlenecking. 4k res would be far less bottlenecking
Disable ULPS via afterburner, if you haven't already.
Its running 14.4 right now, no crashing but there is stuttering while benching. Last time i tried 14.6 i had a whole load of problems like no screen signal at all, then it defaulted to low res and said i had no drivers, so i just cleaned them out and stuck with 14.4.
I was looking at where is said what GPU im using on that heaven score, is the intel HD graphics supposed to be on there? I know its supposed to show up as 2x R9 200 Series but it only showes as having 4gb of memory there too.
the 4gb is normal yeh, and the intel hd bit, just means its not disabled
when running that benchmark you are looking for horizontal lines or messed up triangles
if you not seeing them u usually good
14.6 has crashed on me too, try this driver cleaner next time it fixed it for me
http://www.guru3d.com/files_get/display_driver_uninstaller_download,10.html
what cooler you have on your cpu?![]()
I had trouble with installing 14.6 too with my R9 295X2. Took a couple of goes but all seems to be fine. Getting the kinda 3d mark score I expected off this (ie 2x my 290x score). Haven't tried Heaven yet, will do this weekend and let you know what I get.
