- 10 May 2012
- North London
Ok, 34 it is.![]()
Although having said that lol....I'm no expert...I'm not even using the proper leads ...but the monitor is nice though
Ok, 34 it is.![]()
You are going to be blown away by the quality when using the proper cable!No idea how you have used the monitor for this long with that DVI cable
as using a DVI cable with a DVI-D monitor looks beyond terrible! Text etc. is completely unreadable, even HDMI looks far better!
TBH, if I wasn't aware of the cable stuff, I would have thought that the monitor was brokenas using a DVI cable with a DVI-D monitor looks beyond terrible! Text etc. is completely unreadable, even HDMI looks far better!
hehe, I better start whoring the AA again in bf 4 to make sure that doesn't happen![]()
....it's hard being hated for using the AA sometimes lol
The 34UM65 link here says it's £449.99 but after clicking the web site says £479.99 ....... which one is correct? (very tempting at 449.99 *cough*)
Lol but...it does allow me to hit helis way up very high lol...but I will give some other options a go
just as well cos i'm rubbish with on foot gun to gun...where as my daughter is pretty hot in bf3 at team death match
You need DVI-D, that cable image you posted is just DVI.
So this here is what you need:
http://www.overclockers.co.uk/showproduct.php?prodid=CB-066-OK
The connection/pins should look like this:
Don't bother when they are too high up, just wait till they get closer then shred them with the 30mm cannon
Zunis are great against groups of infantry and tanks/lavs.
Infantry play in bf = PFFFFFFFFFFT, vehicles is where it is at!![]()
Just thought I would chime in on this for some clarification (could be read nitpicking...). Both the cable that foster grant linked to and the cable that Nexus18 linked to are DVI-D (DVI Digital). The difference is that the one in Foster's link is only single link where as the picture that Nexus 18 showed is dual link.
Single link DVI has a maximum supported resolution of 1920 x 1200 @ 60hz while dual link DVI has a maximum supported resolution of 2560 x 1600 @ 60hz or 1920 x 1200 @ 120hz.
In summary, Nexus18 is entirely correct that the cable is the problem, and he has linked the correct cable for the solution, I just wanted to clarify the reasons why.
Cheers
What cables, if any, actually come with the monitor?
Depends on what you're using your monitors for, I game and use my secondary one to keep an eye on other things so one big one wouldn't be very useful to me.
