** ACER MAKE G-SYNC AFFORDABLE TO ALL!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Acer are really doing great G-Sync promotions, they gave me such a great price I have taken an entire container of these:-
Acer XB270HA 27" G-Sync 144Hz Gaming Widescreen LED Monitor - Black/Red @ £367.99 inc VAT
Acer XB270HA gaming monitor as the world’s first 1080P 27" display featuring NVIDIA® G-SYNC™ technology to provide stunning, ultra-smooth, tear-free imagery and rich colors for outstanding gaming experiences. It features Acer’s flicker-less, low-dimming and ComfyView technologies that reduce strain on the eyes for smooth and comfortable extensive viewing.
The Acer XB270HA is intended to be paired with enthusiast PCs for immersive, ultra high-end gaming. It features a spacious 27-inch LED backlit display with True HD (1920 x 1080 pixels).
With a GeForce® GTX™-powered PC, NVIDIA® G-SYNC™ display technology synchronizes the display’s refresh rates to the GPU to eliminate screen tearing and minimize display stutter and input lag to deliver smoother, faster, more breathtaking gaming experiences. Scenes appear instantly, objects look sharper and more vibrant, and gameplay is more fluid and responsive providing gamers with significant performance advantages.
The Acer XB270HA features 170/160 degree viewing angles so that brilliantly-colored images can be seen from almost every angle. DisplayPort™ v1.2 transmits video signals and four USB 3.0 ports are conveniently located at the side and bottom of the display for connecting to keyboard, mouse or mobile devices.
The Acer XB280HA monitor is made with post-consumer recycled plastic and features a distinctive red ring on the base stand. The multi-functional ErgoStand allows the screen to tilt from -5° to 35° to ensure the best viewing angle; the base rotates 120° from left or right for easy screen sharing; the panel height can be raised by up to 150 mm for optimum comfort; and the screen pivots from horizontal to vertical for more viewing perspectives.
This eco-friendly monitor features a mercury- and arsenic-free panel, LED backlighting for reduced power consumption, and is ENERGY STAR®(1) qualified.
Features:-
- Flicker-less technology – stable power supply eliminates screen flicker particularly beneficial for heavy users by helping to reduce eye strain.
- Low dimming technology – adjust to as low as 15 percent brightness in low light environments to make it easy on the eyes. Standard monitor settings start at 30 percent brightness level.
- ComfyView technology – the non-glare panel reduces reflection from light source.
Specification:-
- G-Sync Technology
- 3D Vision Technology
- Flicker-less Technology
- Height Adjust stand with tilt, swivel and pivot
- Display Screen Size: 27"
- Aspect ratio: 16:9
- Panel Type: TN
- Brightness: 300cd/m2
- Contrast Ratio: 1000:1 (Typ)
- Dynamic Contrast Ratio: 10,000,000
- Resolution: 1920x1080 144Hz
- Response Time: 1ms (GTG)
- Colurs: 16.7M
- Bits: 8 bits
- Viewing Angle (H / V ): 170 ° / 160 °
- Connectivity: 1x DisplayPort 1.2 (144Hz)
- USB Hub 3.0: Yes (1up, 4down)
- VESA: 100x100mm
- Speakers: No
- Warranty: 2yr
Only £367.99 inc VAT.
ORDER NOW
That's an epic price for a 27" 144Hz 1ms G-Sync enabled monitor - THANK YOU ACER!
No excuse now guys, we've only got 320pc of this model to go round, so get your orders in quick if you want one come September, we expect these to sell like absolute HOT CAKES!
What a bargain its nearly the same price as the Asus VH278HE 144Hz and BenQ 27" 144Hz monitors without G-Sync!!!!
No excuses guys, GET YOUR WALLETS OUT!!!! :D :D :D
Gibbo, does this come 3d vision certified? Would be a deal breaker for me tbh as I'd like a 27" 120/144hz gsync/3dvision monitor to run along side the 4k gsync I just ordered :D
Sold.
Will get one ordered at the end of the month :D
So much for the gsync premium, well played Acer.
Yes it's so cheap as it's got a full adjustable stand and usb3.0 hub too. Fact it's got G-Sync too is incredible!
You say 'affordable'. I do not think it means what you think it means.
It does mean what he thinks it means.
It was widely regarded that the G-Sync module would add significant cost to existing spec monitors. Which in some part was true with the initial DIY Asus unit and then the horrendously over-priced ROG Swift.
Acer (And AOC to some extent) have basically put out these monitors with the same spec and pricing as other monitors with the G-Sync feature essentially thrown in free.
Samsung 4K = £499
AOC 4K = £499
Asus 4K = £599
Acer 4K G-Sync - £499
No added cost.
Asus 27" 144hz 1080 3D = £349
Benq 27" 144hz 1080 3D = £359
Acer 27" 144hz 1080 3D G-Sync = £367.99
Very very minimal price difference.
Does it come with a pair of glasses for 3D or are they a separate buy? At £80 they are a fair bit but understandable if not bundled at that price.
does it come with a gaming pc & will it make me breakfast in the mornings :D. really good price I might just have to order one
Might sound a tad silly, If I use an Oculus Rift with 3D enabled, what happens..? I know Oculus is somewhat "3D" but hopefully you know what I mean.
it's a step in the right direction and should force everyone else to rethink any large premiums added onto these types of monitors
I am not really a fan of Acer but i have to take my hat off for this and the 4K G-Sync offerings. They easily could have undercut Asus by £50 and sold a bucket load but this really is a kick in the nads for Asus and hopefully a wake up call for them to get a grip of their pricing structure and not take the mick.
spoffle:
May just have not been thinking, I was saying enabling 3D on the monitor, then using the Rift, what would happen. But the 3D is only effective with the special glasses right?
oh
can't wait till 1440p 144Hz is a reasonable price
To be honest, 1080p is plenty. You also need some serious grunt at 2560x to achieve 100fps+
I recently went from 2 x DELL 2560x U2713HM to 1 x DELL and a 1 x BENQ 27" 144Hz... and I am never playing an FPS game like BF/CSS on a monitor with <120fps refresh again. It's a different type of game.
I am not pre-ordering because I don't believe in it - nor do I like the way OCUK take your money two months+ before - but I will be buying one after release.
But credit to OCUK for getting a date and decent price for this
144Hz and GSYNC < £400 - epic
Well plenty say they won't go back to 1080p after experiencing 1440p ;) For me both 1440p and 144Hz is the best option :p I agree though it's still an epic deal for what will be a great monitor
