- 25 Nov 2011
- The KOP
Wait until you upgrade to 7.1!!!
Have no reason to believe I need to any time soon.
Have no reason to believe I need to any time soon.![]()
Don't you think though the extra drivers will help pin point that extra bit more though?
Still a lot games also that I have seen don't support 7.1 yet I know csgo 5.1 is max. I would after look but from top my head don't think I have seen 7.1 yet as a option to select.
I don't have an AMD card but isn't true audio meant to be very good? So isn't that atleast a tiny advancement?
Don't know never used them. Don't really like the idea of 10mm drivers that you find in the 7.1 headsets. 5.1 does me for now.
Hate how text doesn't carry sarcasm as much as I need it to.
I heard the difference it made to the Man of Steel album. The positional demo's are accurate using a good set of headphones and a headphone amp. Turtle Beach have encompassed the technology on the 600 and 800 series I believe?
Try this, there is a little album from the free DTS Headphone:X audio samples ripped from the Z+ Music apps from Hans Zimmer; Gotham City:
http://www50.zippyshare.com/v/24384337/file.html
Click the Orange download now for those who don't know how to use zippy share.
even my G4me ones work perfectly with this.
I'm using an STX II and G4ME ones at home and I have pc350 and a EPH-O2D at work.
both this and the barbershop one are easy to listen to and get a feel for positional audio.
but like I said in FPS games a lot of it is associative sound. On Office in CSS you can hear the hostage being rescued from by the filing cabinets in mid but only the hostage to the right of T spawn not the one in the projector room.
Same goes for the dodgy sounds in csgo there are parts of certain bomb sites that the sound isn't quite right and that will tell you where they are more than the headphone.
I remember when someone made a D2 christmas map and the sound was screwed with Hard footsteps on dust soft ones in tunnels. I just couldn't tune my brain to it at all. people running down short sounding like they are on long and people running long sounding like they are short.
That is very creepy haaa freaky when he walking behind you am going to cut your ear haaa
I did the same thing with one of my Rode microphones on the DSLR. A decent stereo setup really is amazing. 5.1 headsets? Please...
Video:
No it's stereo.
Don't like dolby me, makes the sound like you standing inside a hall very echoey.
If you going to use stereo I would just use them as is. But no problem in trying yourself.
