Caporegime
- 18 Sep 2009
- Dormanstown.
GTA4 was a direct port from the ps3 version. It ran on just two cores and hated multi gpu
Gta5 will run on the more updated rage engine, games like max payne 3 used it and ran great. You then have next gen using same x86 so development should work more easily.
Crossfire will work and your i7 will get used. So it will in theory work much better.
Watchdogs. Performance isn't guaranteed.
Think you have a valid point with the rage engine though.
