***The Vapers Lounge***
Status
Not open for further replies.
as others, buy seperate if you can, vapers emporium or go4smoke are cheapest for nic base,
VG and PG from classikool on Ebay or you can get VG in Boots.
I find Chefs Vapour stock loads of different makes of concentrates, use code AAEC for 10% off. and it saves on postage getting them all from the same place.
Oh and some French Vanilla Deluxe will make your Custard taste even better ;) and PA vanilla custard tastes as good as Capella but is cheaper
A really good VC recipe is the first one here, imo its nicer than GVC
http://allaboute-cigarettes.proboards.com/thread/26864/members-eliquid-recipes-vanilla-collection?page=1&scrollTo=491446
Fair play, it would be good if i could get most or all of it from one place, but cant find anywhere where its all in stock..
Shall keep looking. :)
Need some advice for the sister bf.
I got them both into vaping to get them off the stinkies and they have both been using Evod's and are both loving it. My sister is still happy with the Evod but he has been eyeing up my Vamo & Aerotank in envy recently.
Is the Vamo still a good variable voltage device to go for, or is there anything else he should be looking at in a similar price bracket?
I have been happy as anything with my setup for ages now so have not been keeping up with things.
I get most of mine from Chefs Vapour, use code AAEC for 10% off.
I find Perfumers Apprentice Vanilla Custard as good as Capella
http://www.chefsvapour.co.uk/Vanilla_Custard/p1901058_11483624.aspx
French Vanilla Deluxe (sold out now) http://www.chefsvapour.co.uk/French_Vanilla_Delux/p1901058_11133785.aspx
Sweetener http://www.chefsvapour.co.uk/Sweetener/p1901058_11483622.aspx
Vanillin Crystals (just put 1g into a bottle and dilute with 10ml of PG, Heat it in hot water to help it dissolve) http://www.chefsvapour.co.uk/Vanillin_10__PG/p1901058_11960038.aspx
Which mod do you guys find works best? I have the 'MultiVape' mod that they have started selling in my local BP garage, and so far it's pretty impressive.
However, it's quite large (about 6 inches in length), you don't get any spare clearomizers or batteries, and they are £9.99 each (the clearomizer and battery that is). New to vapeing (smoker for 12 years) and I have no idea on any other mods/liquids etc so I'm trying to learn :)
I don't want anything expensive as money is a bit tight at the moment (Baby due in Sept), but I need something that will last a fair while so I don't have to keep buying replacement parts. Is my 'MultiVape' going to last a fair while before other parts are needed? Or I guess you just can't tell?
Any advice would be much appreciated. Thanks :)
Right I am a but drunk and peeeved off with the world so please understand. :cool:
My mum has been diagnosed with lung cancer and I really want to stop smoking soon. She only 20 years older and my pants are a little brown so to say.
I have tried a few vapes and e-cigs but they always make me cough.
Now I really want to stop, not right now although I should but I have a plan. ;)
Question
Does anyone else cough if they vape?
Is it the temp the product or voltage that can control the cough I get?
I might go cold turkey but I have bad habits so its very hard.
Question
Sorry to hear about your Mum mate, bad times. :(
I'm a newbie to this, but I'm sure the cough you are experiencing is 1 of 2 things, or both. Either it's one of the side effects of giving up smoking (all the crap coming off your lungs as they repair themselves) or it's the strength of the nicotine in the e-juice. You can get different strength e-juices that range from zero nicotine, all the way up to 46/48mg (I think?) Your average ciggie contains around 15mg of nicotine.
For example. I smoked around 10-15 roll ups a day, so I started on 18mg juice. This was a little strong for me and did make me cough like hell, so I've moved down to 12mg nicotine and it's a lot more bearable.
Someone please correct me if I'm wrong.
It really depends on how you view it. Doesn't really matter what you buy, as you will likely spend more on real cigarettes anyway. So, in my opinion, you are probably best to spend your money once, and spend it right. You could get cheaper gear, but it will cost more in the long run.
So you have to decide if you would prefer to cheap out, or go all in. Remembering of course, that if you decide to quit vaping, the gear should still be worth something, and unlike almost everything else second hand, the values usually remain quite high.
So, with that in mind, I'll tell you what I would do if I were you, knowing that this is working for me, and wanting the most cost-effective long term solution.
I would go for a kayfun clone. This is the atomiser / cartridge element. This will come in a little over £20 depending on where you buy it. If you can wait on the slow boat, it will be a few quid cheaper, otherwise you can source in the UK. Make sure it is the V2, as in this link :
https://www.fasttech.com/p/1700500
Ideally you'll be wanting a couple, so you have back-ups, and can easily change flavour, but that is up to you. The reason I will advise this is that it is a very good clone of a high end atty. It is completely rebuildable, so you make your own coils. Something that can be daunting at first, but in reality is very simple.
Now the reason you want to go rebuildable is that making coils is very cheap. You can buy 50m of Kanthal wire here for £6.50 and a single coil will only need 10cm tops, and should last many weeks : http://www.vape-atomizer-mesh.com/p...Micron-or--28-AWG----50-Metre-Spool-2437.html
Wick can be made from cotton wool. A substance you are about to have LOADS of with a new baby on the way, but you use very little anyway (although you will probably change the wick every few days), and it is very cheap to buy. This works out a LOT cheaper than replacing heads on regular atties, which are often £2-£3 per head, and will only last a couple weeks tops.
There are LOADS of youtube videos out there that explain how to make your own coild using these materials on this device, so you should have a wee look.
Then you will need a mod. Something variable wattage would be preferred. I have a couple Vamo's and quite like them : https://www.fasttech.com/products/1411/10004394/1491700
Thats another £20. You will also need batteries and a charger. These batteries, and this seller are excellent : http://www.ebay.co.uk/itm/2x-Torchy...rElectronics_Batteries_SM&hash=item4622c783c5
Then, for a charger, this would do fine : https://www.fasttech.com/products/1421/10001638/1319800
That's probably what I would go for, or you can bin the vamo, batteris and charger for a MVP V2, which is a great little device. Can be had for £37 here in the UK, http://myepack.co.uk/mods/itaste-mvp-v2-0-metal-grain.html charges via USB, and is VW etc. But, once the battery is dud, the whole device needs changed. And with the Vamo, if your battery dies while out and about, you can just change it. Not possible with the MVP.
So, it seems like a lot of money to kick off, but actually, once you have it all, keeping vaping will be very cheap. Really just your e-liquid you'll be needing from then on, and places like Joose Juice (https://www.joosejuice.co.uk/shop/c...dYE1MhOVFEwx36iJJw2aEIvYErGu&shop_param=cid=&) do 10ml for £1.50.
Get set up with the correct gear first, and you can save yourself a LOT of money long term, and at the same time, have a better vaping experience. AND have some residual value left in the products. Them multivape things are pretty much worth nothing as soon as you have opened the box.
Short term cheap option. Just buy the Ego Kits from Home Bargains at £5.99. They aint great, but they will do the job. Will need replaced reasonably regularly though... http://allaboute-cigarettes.proboar...ebargains-5-99-ego-kit?page=1&scrollTo=735498
Above is spot on.
I went for cheap and nasty setup when I first started vaping.
And it was only a week before I realised I needed better, and ended up with a vamo v5 and aspire and wish I had started with this from the start instead of wasting money on the cheaper kits.
Now onto mech mods and drippers because I do like them nice big clouds :p but a decent mod and atty (they Kayfun as suggested above and making your own coils is great advice) and you will be very happy.
Yep, its should be on the front page. :)
MVP2 + a Kanger Protank 2 or Aspire BDC etc is a good way to start too, if you dont fancy jumping straight into rebuildables. But a Kayfun is very easy to use and so much better than a KPT or BDC, and cheaper to run too.
Anyone going to Vapefest?
http://ukvapefest.com/
I'm going with a friend.
Does anyone care to use the day for a bit of an OcUK meet? Would be great to put faces to the names!
Plan on picking up a nice copper setup for some cloud chasing :-)
I'd like to go, but only really the GF that would come, I have no real life vaper mates lol, Just one that has a cigalike and refuses to get some real kit. :D
I'm down just outside London too, so its a bit of a stomp. If we go I can see myself spending too much money!
All of that for me too. Except I'm just South of Aberdeen, so a real trek for me too, and my wife wouldn't come.
Boooo, there is always more excuses to not do something than there is to do it :p
Have you ever watched this event on youtube? It's like the Cantina bar from Star Wars!
Bought an EVOD starter kit a couple of weeks ago (as NRT with a view to quitting) and cappuccino oil from vapeland. It's a pleasant change from stinkies (now totally understand why they get nick-named that) which I use in the evenings when back at home.
However, the stupid things leak though! On every refill. A mouthful of oil isn't the most pleasant of things. If left standing on mouthpiece, only leaks when down to 1/4 in the tank. If left standing on battery end, leaks no matter how much in the tank.
Don't fancy a soggy pocket at work, hence still on the stinkies.
Anyway to stop these leaking?
Evod tanks shouldn't leak at all, perhaps yours is duff. I use one for out and about and it's never leaked. Get yourself a new clearomizer, they're dirt cheap http://myepack.co.uk/clearomizers/kanger-evod-clearomiser.html
Status
